Old 10-17-2014, 07:49 AM   #71
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Randy, yes I was using the four new screws that came with the kit. The holes in the cover were slightly too high to match the holes in the new converter, thus requiring a bit of reaming on the bottom of each hole (on the cover) to allow good line-up. Not visible to the eye after the cover was replaced.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-17-2014, 09:55 AM   #72
New Borockton , Alabama
Images: 21
I get it now. They are brown. The other kits are silver. Regardless they should fit perfect. Sorry for the inconvenience. Never heard that before.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 10-17-2014, 10:09 AM   #73
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
My issue was probably my fault as I didn't even notice the screws until I couldn't get the originals to fit. I then looked further in the package and found the little brown ones, but one had the head twist off right away. I had the same alignment problem, but solved it with a little prying. Still can't find a match for the brown ones so cover is being held on by 3 screws, which only I notice.
George
gandttimes is offline   Reply With Quote
Old 10-17-2014, 01:17 PM   #74
TinTin's Avatar
Canmore , Alberta
George:
You could dab suitably coloured paint on the ends of the silver screws. it's unlikely they'll ever come off again.
Bob and Nancy
Old 10-17-2014, 02:24 PM   #75
interstateflyer's Avatar
2017 25' International
Los Osos , California
Just replaced the OEM converter in my 2014 with a PD4655D. I was thinking of listing the old one on Craig's List. I hate to just toss it.
Does anyone happen to know the brand of the original? The label says Model 7355.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 10-17-2014, 02:31 PM   #76
TinTin's Avatar
Canmore , Alberta
Parallax is the brand, I believe.
Bob and Nancy
Old 10-17-2014, 06:06 PM   #77
Images: 21
It is Parallax. Actually, Parallax Power Supply.
Old 10-17-2014, 06:56 PM   #78
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
I would not post my old Parallax except on the list of ingredients for my trash can.
Old 10-17-2014, 07:57 PM   #79
lewster's Avatar
Naples, FL , Hood River, OR
Actually, the old battery burner would make a decent DC power supply for the bench. Knowing that it's a constant 13.6 VDC actually might have some benefit for straight DC requirements.
Just don't go charging any batteries with the old beast!!!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-17-2014, 08:44 PM   #80
Images: 21
Lew has a good point. It's 13.8 but if you were powering a HAM radio or something like that in the shop, it should do fine.
Old 10-17-2014, 11:44 PM   #81
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Originally Posted by TinTin View Post
George:
You are right TinTin. Sometimes the obvious is too hard to see. Thanks.
George
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Converter relocation FrankR Batteries, Univolts, Converters & Inverters 0 07-31-2002 08:30 AM
Converter box floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 10:34 PM
Converter box for into floor mount FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-15-2002 09:49 PM
