Old 03-19-2017, 05:45 AM   #1
2016 25' International
Gaffney , South Carolina
PD 4655 Quick Question
I just installed my PD converter. On the 12v DC board the battery pos lug was a bit loose on the board and could rotate as I tightened it. Is this OK or do i need to get a replacement before going any further?
DT57 is offline   Reply With Quote
Old 03-20-2017, 12:03 PM   #2
HD Pilot's Avatar
2017 23' International
Decatur , Texas
All I can say is that I had the same thing happen to me but with one of the smaller dc fused circuits. I was worried too but the "grip" on the wire seemed good, so I left it as is and have had no problems. I will add that I did not use high forces on that screw, I have worked with a lot of small fasteners before and was using very light torque on that screw.
HD Pilot is offline   Reply With Quote
Old 03-20-2017, 10:13 PM   #3
New Borockton , Alabama
Images: 21
There is plenty of connectivity. They don't torque them too tight so that you won't either.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Replaced a Paralax 7355 with PD 4655 converter Rrroberts40 Electrical - Systems, Generators, Batteries & Solar 87 04-30-2018 09:09 PM
Progressive Dynamics 4655 (PD4655) noise waldosgone Electrical - Systems, Generators, Batteries & Solar 47 10-31-2017 12:56 PM
PD 4655 install video. AWCHIEF Batteries, Univolts, Converters & Inverters 40 08-08-2015 01:34 AM
PD 4655 Question? rgwatkin Batteries, Univolts, Converters & Inverters 7 07-08-2015 02:51 PM
PD 4655 - How long to Float Voltage? Alphonse Batteries, Univolts, Converters & Inverters 6 10-09-2014 12:58 AM
