Old 07-19-2015, 08:16 AM   #29
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by graysailor View Post
ACHIEVE anxious to hear how your install went. Not terribly handy myself but on occasion I surprise myself. Tempted to try this one myself.
Other than the heat, it went smooth thanks to the advice and input from many here. Actually working time was less than an hour. I think I could do another in about 30 minutes. It is one of those jobs that looks daunting until you do it one time and then you wonder what all the worry was about.
MICHAEL
Old 07-19-2015, 02:32 PM   #30
AWCHIEF's Avatar
Images: 33
Question,
The new converter has been installed for 48 hours. When initially put on line it went to rapid flashing light with an out put of 13.66 volts. Currently that has not changed. Per the manual I have tested the different stages to ensure proper operation of each. Current DC parasite draw is gas detector, microwave clock and Fantastic Fan on low. For the first 40 hours the fan was not on. What is a reasonable time to expect the battery to reach 100% capacity or high enough for the converter to go to float stage of 13.2 volts?
MICHAEL
Old 07-19-2015, 03:26 PM   #31
richw46's Avatar
Lexington , Kentucky
When I swapped mine out last month I think it took about a day for it to reach that point. I have 2 sets of Lifelines, I had the older set in the trailer and it seemed like it was going to run forever but it eventually dropped down to 13.2. I was happy to see the higher voltage. On the old, original unit I never saw it go above 12.5. I'm happy with the exchange
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 07-19-2015, 03:45 PM   #32
AWCHIEF's Avatar
Images: 33
Rich, thanks. I guess patience is the key. My batteries seem ok, but they have been a bit mistreated.
MICHAEL
Old 07-19-2015, 07:14 PM   #33
AWCHIEF's Avatar
Images: 33
Yippee, full charge achieved. Converter output is now showing 13.27 volts, single blinking green light every 6 seconds.
MICHAEL
Old 07-19-2015, 07:26 PM   #34
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I've been following this thread and have gotten a lot of good ideas.
Michael, I'm glad your project went well, and you've convinced me to look at a PD4645 to replace the charging section of the 45A Magnetek unit in our Avion. I'll do that before I move my AGM batteries into the trailer.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 07-19-2015, 07:30 PM   #35
AWCHIEF's Avatar
Images: 33
Paul, the best price I found delivered with Prime was on Amazon.
MICHAEL
Old 07-19-2015, 07:34 PM   #36
PaulnGina's Avatar
Good Ol' , USA
Thank you. I was looking at Amazon when I saw this update pop up!
1987 Avion 34W
Old 07-20-2015, 07:19 AM   #37
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
fyi: I had the same amount of time before I got the slow blinking light too, about a day and a half. I have had the FF running and he fridge - when the AS is on the driveway, it doubles as a beer fridge
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 07-20-2015, 09:08 AM   #38
2014 23' FB Flying Cloud
Mill Valley , Left Coast
Did mine this weekend also. Only problems were that I had to remove the four screws holding the whole unit to the wall to access the two hole screw clamp on the DC feed wires from the battery to get the needed length to correctly route these wires to the new distribution section. Also forgot what was posted in an earlier post about installing the little communication cable prior to sliding the unit back in. No big deal, just would have been a little easier had I remembered the earlier advice on this.
All in all 2/10 for difficulty. Easy!
jbxx is offline   Reply With Quote
Old 07-20-2015, 09:52 AM   #39
AWCHIEF's Avatar
Images: 33
Thanks to obsessive over reading of all the suggestions here the first thing I did after removing the covers was remove the entire box and loosened the strain clamps. The wires would not easily have reached otherwise. Agree a 2/10 for difficulty thanks to all the assistance offered here. Being forwarned of potential problems saved a lot of frustrations.
MICHAEL
Old 08-07-2015, 09:31 PM   #40
Subzero-AK's Avatar
2014 25' Flying Cloud
Anchorage , Alaska
Like the others have said here, this is a worthy upgrade. To me it's disappointing that we have to do this upgrade in the first place, I generally expect quality when I pay good money for it. Enough belly aching, the upgrade was pretty easy.
I ordered my PD4655V from Best Converter after looking on Amazon. Even Amazon wanted to charge me about $60 to ship it to Anchorage, I got mine shipped for $45. Yep, I can be a cheapskate. When it comes to shipping things to Alaska, FedEx and UPS tend to forget Anchorage is their second largest hubs for distribution. My package arrived USPS in 4 days in perfect condition.
When I got home tonight, I grabbed some tools and a beer and went to work. I found the instructions to be perfectly clear. My only bump was having to remove the whole unit to loosen the clamps so I could gain a few more inches of battery cables.
As soon as I tightened the last bolt, connecting the batteries and then the shore power, I found that I had the 14.4 V charging already working. I can't wait to go out and find the light blinking slowly indicating the float charge.
Now I need to source some Aluminum C channel so I can extend my battery box for some bigger batteries!
Thanks for the tips...good luck to everyone else who does this upgrade.
Mark
WL7NI
Subzero-AK is offline   Reply With Quote
Old 08-08-2015, 12:34 AM   #41
lewster's Avatar
Naples, FL , Hood River, OR
Mark
WL7NI
You will probably find it easier to find 1" X 1-1/2" rectangular AL tube, which is far stronger than C channel for a battery box extension. Place it with the 1" side down and you'll have no problems fitting 220 amp/hour golf cart batteries in your tongue box.
Try www.McMaster.com for the metal.
Replaced a Paralax 7355 with PD 4655 converter Rrroberts40 Electrical - Systems, Generators, Batteries & Solar 87 04-30-2018 08:09 PM
PD 4655 Question? rgwatkin Batteries, Univolts, Converters & Inverters 7 07-08-2015 01:51 PM
PD 4655 - How long to Float Voltage? Alphonse Batteries, Univolts, Converters & Inverters 6 10-08-2014 11:58 PM
