Old 02-22-2010, 08:00 AM   #1
aftermath's Avatar
Spokane , Washington
Parasitic Drain
Have a simple question. If you hook up two fully charged 12 volt batteries and switch over to "store" mode, how long before the batteries are drained? I have a 2006 25 FB and it is new to me having just picked it up last October. I noticed that even in store mode, some of the monitors are still functioning from the lit led lights visible.
On my SOB trailer, I had a battery disconnect switch which did exactly that. No drain there at all.
Thanks for your expert advice in advance.
aftermath is offline   Reply With Quote
Old 02-22-2010, 08:07 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The "new" standards say things like the LP monitor can't be disconnected. Most people manually disconnect the batteries if the trailer is going to be stored for an extended period. Depending on the age and condition of the batteries, it could be anywhere from a few days to a couple of months before they are drained.
Old 02-22-2010, 08:32 AM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Even with battery disconnected there will be a small and steady loss - the baseline for flooded lead-acid batteries is 1% "self-discharge" per day so depending on exact chemistry it could have 2% to 10% per week of its charge disappeared. AGM and Gel style batteries lose about that amount in a month.
Knowing that - its time to hunt down your accessories data sheets, just lighting an LED for 24 hours may be nearing a single watt-hour but there would be worse losses elsewhere...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 02-22-2010, 05:54 PM   #4
aftermath's Avatar
Thanks for affirming what I feared. The sun came out and it started to look like spring so I ran out and put my batteries in. The trailer is stored some distance away so I will more than likely go back out in a week or two and bring them back home. I can't wait for spring to actually get here.
Dick
Old 02-22-2010, 08:18 PM   #5
New Borockton , Alabama
Images: 21
Expect about 15-20% self discharge per month. The LEDs are powered from DC so that can accelerate the discharge but not too much. Best to leave plugged in if you have shore power and a modern converter with a float mode or if not, a solar maintainer is the answer if you don't want to pull the batteries. Good luck.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 03-14-2010, 05:48 PM   #6
1978 28' Ambassador
Savannah , Georgia
I have kind of the same question: new off the shelf dry cell. Installed 10 days ago. Tinkered around in the trailer for a couple of hours, but not burning all the lights. Today battery is dead. Brought it home and placed on small 12volt charger. How long should I leave it charging? How to check what its charge is? Do you think I have something drawing power even if all switches are off? Will not be able to connect 110 until next weekend...I hope. Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 03-14-2010, 06:36 PM   #7
richinny's Avatar
2011 34' Classic
was the battery charged before installation?
Ricky
Old 03-14-2010, 06:46 PM   #8
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
My trimetric reads a .15-.17 amp draw with the kill switch in the storage position. Even when the SRM-27 Interstates were 'new', with a full charge, within 2 weeks, they'd be 50% SOC.
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 03-15-2010, 05:01 AM   #9
1978 28' Ambassador
Savannah , Georgia
Did not check to see if the battery was fully charged when purchased. Bought it at Sam's. It did have a 2/10 sticker on it, but it could have been there longer than that. Will take it back today and verify charge status. Thanks for advice. Jack
Old 03-15-2010, 09:23 AM   #10
1978 28' Ambassador
Savannah , Georgia
Left battery on 12volt charger for 12hours. Took it and had it checked. 580 amps on a 550 amp battery. Guess charger does work. Hooked it up to AS and lights back on. Thanks. Jack
a/c drain ??? hill4th@gvtc Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-20-2006 09:33 PM
Drain from nowhere? niftypkg Plumbing - Systems & Fixtures 10 02-18-2006 08:33 AM
Are drain valves necessary? nickcrowhurst Fresh Water Systems 9 11-26-2004 07:37 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
A/C drain??? dedko Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-25-2003 12:47 PM
