Old 05-25-2012, 06:39 PM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Parallax Converter
I have a 7300, model 7355, that is a year old. It has started tripping the re-set switch. This kills all the wall outlets in the front of the trailer and also switches the frig to gas. I really do not have all that many things plugged into the wall outlets. No more than what I have used in the past.
Any suggestions as to why it is tripping?
gaylejoe is offline   Reply With Quote
Old 05-25-2012, 08:48 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Are you losing power to the 120 volt AC outlets? If so the device is an Inverter. It may be overheating because the fan doesn't start and run.
Like most electronic devices, they do fail after a while, but yours is a bit premature.
Are you sure you don't have something like a hair dryer or other high current device plugged in somewhere?
Old 05-25-2012, 08:49 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The heating element in the refer may have failed. Try unplugging the refer and see if the Inverter holds.
