Old 07-02-2014, 09:19 PM   #1
2008 25' Safari FB SE
london , Ontario
Parallax 7300 Fan
Hi , I just bought my AS about a week ago, after hooking up to shore power and sleeping in it, I noticed the fan never shut off on the converter. Does anyone have any solutions ?
Thanks in Advance
tatone is offline   Reply With Quote
Old 07-02-2014, 09:34 PM   #2
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
First, Replace it with an IOTA DLS 45. If you are not up for that, you might want to check your coach batteries. They might be shorted or not charging correctly. The fan should shut off after a while when the batteries charge up if you have no 12 volt loads excepting the fridge which doesn't take enough current to heat up the load center. - Brad
SuperTrouper is offline   Reply With Quote
Old 07-02-2014, 09:38 PM   #3
One of my batteries was bad when I bought mine and caused current to flow all the time between the batteries. (I have a 2008 27FB). If one battery is bad you should replace both. Search the forums regarding best batteries and also 3 stage chargers (The Parallax is notorious for boiling batteries if you leave it on for days at a time).
Parallax 7300 convertor upgrade problem JackRenner Electrical - Systems, Generators, Batteries & Solar 13 10-02-2012 05:27 AM
Parallax Power Supply Fan Noise Bluto Batteries, Univolts, Converters & Inverters 9 09-30-2012 09:21 AM
Converter fan noise - parallax vs others Jammer Batteries, Univolts, Converters & Inverters 4 05-11-2010 07:59 PM
Magnetek 7300 intallation Craig Murphy Batteries, Univolts, Converters & Inverters 4 03-17-2008 06:16 PM
7300 series converter dhe9 1997 - 2004 Bambi 1 10-15-2004 04:38 PM
