Old 04-01-2010, 08:23 PM   #1
nevada , Nevada
Outside Battery Box
I am moving the propane tanks forward a few inches so that I can mount batteries up front on the tongue just outside the exterior wall.
Question, does anyone have a good pic of a battery or other type of metal box thats mounted on the tongue?
thanks.....I need some ideas.
wolfpack is offline   Reply With Quote
Old 04-01-2010, 09:30 PM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Are you set on mounting a metal box to the A-frame? SOB trailers have angle iron welded to the A-frame so that two plastic battery boxes can be placed inside them and strapped down.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-01-2010, 09:52 PM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I built a box that holds two group 24 batteries between the exterior wall and the propane tanks. I based the design on the original battery box for my 1961 Safari. I think you can see photos of the box if you check under "my images". It was a tight fit, but I have a good 3/8th of an inch to spare. My original box was riveted to the front of the trailer so I used the same method for the new box. That makes sure there is room for the equalizer hitch to fit without obstruction as it keeps the tongue free.
I have been using it for several years and some long trip without any problems.
Sam
samb is offline   Reply With Quote
Old 04-02-2010, 05:14 AM   #4
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
I got this box from Best Converter. The front door was on a piano hinge but wouldn't clear unless I unbolted and removed the threaded rod for holding down the propane tanks. So, I removed the hinge and relaced it with the clamps you see (from McMaster Carr). Now it will come off sideways. For moving batteries in and out I still have to remove the tanks, but just to access the compartment I don't. And, the threaded rod can stay regardless.
dieseleagle is offline   Reply With Quote
Old 04-02-2010, 08:32 PM   #5
2005 19' Safari
GLENDALE , AZ
I saw a metal battery box with hinged lid at Al's RV, that looked similar to the OEM box on our 2005, 19-foot Bambi. You might check out the RV parts stores in your area, as it appears that someone makes aftermarket boxes that might work.
battery box LJH Batteries, Univolts, Converters & Inverters 7 10-14-2008 06:58 PM
battery box bear4500 All Argosy Trailers 1 05-11-2006 04:44 AM
Battery Box ? aviontt Batteries, Univolts, Converters & Inverters 1 04-17-2005 07:31 PM
locks for battery box and propane box Chilao Doors & Locks 11 11-02-2004 06:56 PM
Battery Box aztlanco Batteries, Univolts, Converters & Inverters 5 08-17-2004 05:56 PM
