Old 01-05-2008, 04:28 PM   #1
Robin Stone's Avatar
1977 31' Excella 500
Gastonia , North Carolina
Question Other end of battery cables
Hi,
I have a 77 Excella 500 which I discovered it didn't have any batterys with it , also seems to have some sort of quick connect cables that go to the battery,that are missing. The ones I want have the batterry ends on them.
Does anyone know where I can get two of these?
Robin Stone
ID:	51998   Click image for larger version
Robin Stone is offline   Reply With Quote
Old 01-05-2008, 04:38 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
1 airstream dealer.
2 forklift supply house.
3 napa, slim chance.
john
you call them ferrets, i call them weasels.
Old 01-05-2008, 05:03 PM   #3
Thanks ,John
Old 01-06-2008, 11:09 AM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I hear that these original quick disconnects are quite rare. I was faced with the same problem so had a company fabricate battery lugs, wire and Anderson quick disconnects for one of the two battery compartments. I still have the original quick disconnect from battery compartment to inside fuse box (somewhere in the garage).
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-06-2008, 11:16 AM   #5
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
They can also be a real pain to connect when you put the battery back in. You need to hold an end in each hand with a battery blocking the hole. The setup on my 75 TW is not user friendly.
Richard
Old 01-07-2008, 06:40 PM   #6
That sounds like the way to go, Craig.
Robin
Old 01-07-2008, 06:44 PM   #7
Thanks for the warning Richard , maybe it will be better on my old Excella.
Robin Stone
Old 01-07-2008, 06:58 PM   #8
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Robin
Unfortunate thing PO probably threw the other end away wiff the old batterys. I lucked out I guess,my cables and ends were very corrided but I can use them. Im not sure what batterys u had but mine had Group 27's I found the cheapist price was autozone. My cables on the 77 are long enough for the batt's to sit on the doors and plug or unplug the Quick-Disconnects.
Good Luck
Roger
Mikethefixit is offline   Reply With Quote
Old 01-08-2008, 05:21 PM   #9
Thanks Roger I'm calling Auto Zone,
Robin Stone
retractable cables gregcarleton General Interior Topics 25 08-16-2007 06:06 PM
Charging 12V using TV and jumper cables? Boondocker Electrical - Systems, Generators, Batteries & Solar 21 06-19-2007 10:47 AM
Longer Battery Cables - Replace or Splice? RDM16CCD Batteries, Univolts, Converters & Inverters 3 02-26-2007 11:01 PM
RCA Cables for AV package Tavis76 Electrical - Systems, Generators, Batteries & Solar 3 05-19-2006 08:54 PM
