Old 02-23-2011, 03:00 PM   #1
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Question Operating With No Batteries
Is it safe to plugin when the batteries have been removed?
Where my Daisy is in storage we have no long-term use of electricity. It looks like we won't be using her now until our summer trip in June, so I'm removing the batteries and bringing them home to put them on a battery tender. I occasionally do go over to Daisy and run a long extension cord so I can do some work. Is it safe to plugin?
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 02-23-2011, 03:04 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
It is my understanding that the modern converters don't require a battery to be present.
Old 02-23-2011, 03:08 PM   #3
tpi
Trabuco Canyon , California
If you have the 7355 Parallax converter, a battery doesn't need to be present.
See page 1 of this PDF:
http://www.parallaxpower.com/7300/51...%20rev%20G.pdf
It is important when batteries are removed the positive cable isn't grounded somehow.
tpi is offline   Reply With Quote
Old 02-23-2011, 03:16 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the only 12 volt system you will most likely be using is the lights why not just take a 120 volt light with you and unplug the converter to be safe.
If not you will have to cover the end of the positive cables to be sure they don't short to ground while plugged in.
2004 Excursion 4x4
Batteries won't run Furnace 6PackCharlie Furnaces, Heaters, Fireplaces & Air Conditioning 15 02-19-2018 12:42 PM
Motorhomes, and Charging Batteries.... Keyair General Motorhome Topics 18 10-15-2011 08:21 AM
Batteries say charged but nothing works OKJerry Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 6 06-12-2011 07:03 AM
factory supplied converter and batteries rayandre Batteries, Univolts, Converters & Inverters 9 02-23-2011 05:47 AM
Battery lost a cell. Desulfating or refurbishment possible? Keyair Batteries, Univolts, Converters & Inverters 57 02-14-2011 11:26 AM
