Old 08-01-2004, 06:10 PM   #1
outerbanksdeb's Avatar
Kill Devil Hills , North Carolina
OOPS! battery not charging,water hook up spilling into reserve tank?
1) We drove 3 hours and the lights dimmed and went out. She is definitly not charging her battery while we drive! I tried manipulative therapy but it didn't work. ANY IDEAS!
2) we were hearing the babble of falling water but were not near a creek It seems the water hook up was some how backing up into the reserve water tank and then out the potable watertank fill door(?). made for a soggy campsite!
3) Every time we leave the campsite Mark turns off the water heater, and water. Is that necessary?
Okay, thats it, But we had a fun weekend!
THANKS a bunch! OBX Deb
outerbanksdeb is offline   Reply With Quote
Old 08-02-2004, 12:31 PM   #2
Jim Rogers
jimrogers's Avatar
Jonesboro , Arkansas
Deb,consider putting a check valve in water line on the discharge side of water pump.....make sure wire connector is wired with a 12volt charge from van battery,if it is then check from trailer to make sure it is hooked up....Phyllis
jimrogers is offline   Reply With Quote
Old 08-02-2004, 12:40 PM   #3
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Charging problem while driving
Do you have a two battery system? After looking at the wiring diagrams, I had trouble figuring how the first battery would be charged while driving. It turns out there was an undocumented brass shorting bar between the positive leads of the two batteries. Yours may be missing. If it is gone, the tow vehicle will only charge battery #2 and the Univolt will only charge battery #1.
If you post the model and year of your trailer, maybe someone with the exact same setup can chime in.
sander17 is offline   Reply With Quote
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
