Old 11-16-2015, 07:15 PM   #1
1974 Argosy 26
Joshua Tree , California
One thing leads to another...so why not the power supply?!
We've got a '74 Argossy 26' acquired earlier this year. I'm replacing all the plumbing with PEX and replacing fixtures in the bath. But before I cover it all up and call it finished ... There sits the humming power supply!
While it's still "more" accessible (for someone standing on there head) I think it should be replaced. It's the big blue box Magna Rek.
The real question is this: I've seen Power Dynamics referred to a number of times but also see: Powermax, Parallax, WFCO. Any opinions on these brands? My current supply is 45 watts. Should I consider moving up to 60? No current re wiring is planned.
StarckMad is offline   Reply With Quote
Old 11-16-2015, 08:34 PM   #2
1994 34' Excella
Warren , Manitoba
I have used Progressive Dynamics PD9245 in both my 1976 Sovereign and now my 1994 Excella. They have worked flawlessly and are an easy instal. Good deals on Ebay! Now is the time to replace, if you have things apart. Really extends the life of your batteries, and will pay for itself in a couple of years. Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 11-16-2015, 10:48 PM   #3
1974 Argosy 20
Kooskia , Idaho
And 45 amps is fine, no need to go to 60. Especially if you convert to LED lighting, which I would highly recommend.
Old 11-17-2015, 05:17 AM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
However, if different batteries might be in the future, then the slight difference in price between 45 and 60 amp capacity would be wise. Also the 60 amp box would not generate as much internal heat as it would not be under a full load all the time.
Old 11-17-2015, 12:20 PM   #5
2014 27' FB Classic
Cassopolis , Michigan
While you're at it you might consider installing AGV batteries rather than lead acid. You can put them anywhere, even inside the coach, and they don't discharge any appreciable amount and in my experience last far, far longer. For those to work and charge best you need a charger designed for them, widely available from marine sites.
biyak269 is offline   Reply With Quote
Old 11-17-2015, 01:32 PM   #6
1973 31' Sovereign
Middletown , California
When I replaced the Univolt in my Sovereign with a switching power supply years ago, I made a wood mount for the fuse panel from the Univolt so I could leave all the factory wiring and amp meter in place. Just recently I fried the 45 amp unit by abusing it with a generator so I replaced the first power supply with a 75 amp unit by Power Max that is supposed to have "smart charge" circuitry. Too early to tell how well it works out but the 45 amp unit would run it's cooling fan if I had more than 2 ceiling light fixtures on at one time, and my battery life was short. So far the Power Max seems to work well. Leland
ijustlee is offline   Reply With Quote
Old 11-17-2015, 01:41 PM   #7
2003 30' Classic S/O
Calgary , Alberta
What you have is a older single phase charger. If you do any camping which requires you to stay plugged in for two to five months you will boil you batteries dry and ruin them. With a newer three phase charger/converter once the batteries are fully charged the converter will go to a trickle charge mode or completely shut down until they require charging again. I would definitely change it out. Only my opinion.
hradec is offline   Reply With Quote
Old 11-17-2015, 03:57 PM   #8
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
Say a little more about why the 60 amp capacity would be better if different batteries might be in the future.
+d
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 11-17-2015, 05:21 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The Argosy only has room for 1 group 24 battery. I have the same trailer. The 9245 has worked for me over the last 5 years.
Old 11-18-2015, 10:02 AM   #10
switz's Avatar
2014 31' Classic
Images: 8
Our 300 amp-hour lithium iron phosphate battery is 11.25" x 14.5" and weighs 84 pounds. That is a small footprint with close to 250 amp-hours of power usable and weighs less than the two stock lead acid batteries. It will absorb all the charge power you can give it with a solar system or a programable inverter/charger.
So planning for the future when making equipment purchases today means those dollars would not have to be spent again for the same type of equipment.
Old 11-18-2015, 11:35 AM   #11
1974 Argosy 26
Thanks for all your thoughts and opinions. At this point I'm going to go with the PD 9245. I view this as a basic redo of this trailer and a learning project. I think this will be sufficient. Thanks again!
Bill
One thing leads to another - 1964 GlobeTrottin 1960 - 1964 Globetrotter 11 07-14-2014 12:12 PM
One thing leads to another! Air Dog Mechanics Corner - Engines, Transmission & More... 0 05-25-2014 12:39 PM
one thing leads to another Melody Ranch General Repair Forum 13 05-11-2012 09:24 PM
Why Does My A/S say one thing on one side and something else on the other Angel73 Title, VIN & Registration 3 05-12-2006 09:46 AM
One leak leads to another... Buttercup Plumbing - Systems & Fixtures 24 12-08-2005 10:21 AM
