Old 10-03-2016, 02:56 PM   #1
1976 25' Tradewind
Sulphur , Louisiana
Old 12v circuit board/Univolt '76 Tradewind
Ive got a 76 tradewind with what looks like the original 12v circuit board mounted to the wall behind the guacho. In the middle of the board are the different color 12v circuits. 2 or 3 fuse holders are melted. On the left are the fuses for the running lights/brake lights. The old univolt converter makes a terrible noise when powered on. I want to change all of it. I would like to put a new 12v circuit board on the wall and a new converter on the floor like it is now. I know where to get a new converter/charger but I dont know where or what kind of 12v circuit board to get. Or should I get one of those parallax converters with built in 12 fuse panel? If I get one of those what should I do with the running light fuse panel?
Bobkatbry is offline   Reply With Quote
Old 10-03-2016, 05:40 PM   #2
New Borockton , Alabama
Images: 21
Parallax makes a 9, 12, or 15 position DC fuse board that you can get separate from the converter. Much more simple than pulling new wire to install a full Parallax power center.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 10-03-2016, 09:51 PM   #3
1979 23' Safari
Wayland , New York
Blue sea systems makes nice fuse panels.
Here's what I used. They make a smaller 6 circuit. Get one with the negative bus. I used most of my 12 spaces once moving and adding a few circuits.
https://www.amazon.com/gp/aw/d/B001P...AwL&ref=plSrch
12v
New Circuit Board for Dometic 13,500 Penguin heat pump old p/n 3106682.036 old p/n 3311557000. Shayne50 Airstream Classifieds 0 07-28-2015 09:29 PM
Airconditioner Circuit Board dmreilly10000 Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-20-2006 09:10 AM
1983 Excella 500 - Furnace Circuit Board 4 Sale? Cat Airstream Trailer Forums 2 02-26-2004 02:12 PM
Suburban Circuit Board: $194.65!!! Navigator Furnaces, Heaters, Fireplaces & Air Conditioning 8 02-07-2004 06:13 PM
