07-07-2013, 08:26 PM
1971 31' Sovereign
Big rock
Ok, I'm lost... Help please!!
I have gone thru and changed all the bulbs, fuses , and broken or bare wires. I'm plugged into shore power but don't have any 12volt! Ugh!
The univolt inverter has been changed to the inteli power 9100 model pd9155. It's plugged in. what else do I check? There is a 3/16 solid copper ground running from the inverter. Not sure where it goes to. I'm assuming the frame!?!?
PS also there are no battery's hooked up to the system.
07-07-2013, 08:33 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Post a picture of your set up please.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
07-07-2013, 08:46 PM
Alamo Heights
Put a voltage meter on the outputs for the converter and see if the converter itself is producing DC power or not. If not, make sure the 120v socket it's plugged into has power. If not, check the breakers, cycle each one off and then on and re-check the 120v socket.
If the 120v socket has power but the converter doesn't produce a bit more than 13v, check for fuses on the converter itself.
If the converter produces DC output, measure across your fuse block to make sure DC is available there.
I'm assuming you either don't have battery cables attached at the fuse block, or you made sure the positive cable is isolated to prevent a short before plugging in without a battery installed.
— David
07-07-2013, 08:55 PM
1969 29' Ambassador
brooksville
Also check to make sure you have a good ground. You can also ground out to the body if needed. The bare copper wire could broke at some point.
Not all those who wonder are lost.
07-07-2013, 09:22 PM
1971 31' Sovereign
Big rock
Ill post some pics in the morning
07-08-2013, 09:45 AM
1971 31' Sovereign
Big rock
Ok my inverter is plugged in. How do I check to see if power is going out of the unit itself? Please explain it like I'm in grade school. I've never used a volt meter or even a test light.
07-08-2013, 10:07 AM
Alamo Heights
OK, first, to avoid confusion from someone who didn't read this thread from the beginning, or someone you might call from an RV repair place, the thing you're working with right now (PD9155) is a converter (or converter-charger) rather than an inverter.
Looking at a photo of it, I see that there are 2 positive and 2 negative outputs (with a red label above the positive, and a black label above the negative.) Do you have a DC voltage meter or a multimeter? If so, you want to set the meter for measuring DC, and if it's not an "auto ranging" type you want to select the setting for something like 0-20V (that will vary by brand, but you want to pick the lowest setting that has the top of the range at or above 15V.)
Being careful not to let the 2 probes touch (in case they have long exposed areas) touch one probe to one of the outputs with a black label, and the other to one of the outputs with a red label. You can either put the probes on the screw heads that tighten down on the cables, or into the opening where the cables go.
You should expect to see more than 13V while the converter is operating properly.
— David
07-08-2013, 10:27 AM
1971 31' Sovereign
Big rock
Here are pics if the converter/charger. It only has one positive and one negative output
07-08-2013, 10:46 AM
Alamo Heights
Even simpler, only one to choose from on each side. I see now that even though I searched for photos of a PD9155, I ended up with a photo of a PD9160a (perhaps the current replacement model for the 9155?)
The rest of the instructions are the same, you simply have only one of each output rather than a pair of each.
— David
07-08-2013, 11:00 AM
1971 31' Sovereign
Big rock
I'm heading to get one now. I'm going to change out my 12v distribution fuse panel for a less complicated AR breaker setup. I'm posting a pic of current panel set up. Notice bottom left the power on white wire is missing. Could this be my problem with exterior lights? If so where can I pull this wire from?
07-08-2013, 11:10 AM
Alamo Heights
You're missing a fuse for one of the primary circuit negatives (the rightmost black cable.) Where does that cable go?
— David
07-08-2013, 11:27 AM
1974 Argosy 26
Morrill
, Nebraska
The exterior lights are not powered by the converter. That power comes from the TV. Only the 12 volt devices within the trailer are wired to the converter, via the fuse panel.
If the UCord is wired to match the TV, the exterior lights should come on when you turn on the head lights. Marker and tail lights, that is. The brake and turn signals will flash when you turn on the emergency flashers.
The electric brakes and charge line are also wired thru the UCord as well as the common/ground from the TV.
07-08-2013, 01:05 PM
1971 31' Sovereign
Big rock
I have replaced all the fuses. And yes I know the TV supply's the current for those things. What I'm asking is where do I pull that white power on supply from? The panel shows white wire coming in the bottom of that amp fuse and gray wire out.
07-08-2013, 03:13 PM
1971 31' Sovereign
fort myers
I think a 12 volt battery needs to be in place to pass the 12 volt supply. I could be wrong. That happened once in 1977.
07-08-2013, 03:30 PM
1971 31' Sovereign
Big rock
It's for the distribution panel that converts 110v to 12v
07-08-2013, 05:04 PM
1971 31' Sovereign
Big rock
I replaced the missing or bad fuses, the black on the far right is a negative battery cable for 2nd battery
07-08-2013, 05:22 PM
1971 31' Sovereign
Big rock
This is what I get when I do the procedure that you explained.
This is the probes connected at the fuse block before the fuse
But if I connect on the lugs after the fuses I get 13.7
If I connect at the lugs on the converter I get a reading of 1.31 don't make any sense
07-10-2013, 06:39 AM
1971 31' Sovereign
Big rock
Anybody have any input? Need help figuring this out.
07-10-2013, 09:03 AM
1974 Argosy 26
Morrill
, Nebraska
Tell us where the black and white wires from the converter connect to the fuse panel.
I don't think you are getting a good reading with your meter when it reads 1.31 volts.
Where are you reading the 13.7 volts? It must be coming from the converter. Since apparently you do not have a battery installed.
07-10-2013, 09:39 AM
1971 31' Sovereign
Big rock
Ok I'm getting a solid 13.7v out of the converter and 13.7v across the fuse block. I have lights on my control panel above the stove. But nothing beyond that.
