Old 07-07-2013, 08:26 PM   #1
Woodweavil7's Avatar
Southside , Tennessee
Ok, I'm lost... Help please!!
I have gone thru and changed all the bulbs, fuses , and broken or bare wires. I'm plugged into shore power but don't have any 12volt! Ugh!
The univolt inverter has been changed to the inteli power 9100 model pd9155. It's plugged in. what else do I check? There is a 3/16 solid copper ground running from the inverter. Not sure where it goes to. I'm assuming the frame!?!?
PS also there are no battery's hooked up to the system.
Woodweavil7 is offline   Reply With Quote
Old 07-07-2013, 08:33 PM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Post a picture of your set up please.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-07-2013, 08:46 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Put a voltage meter on the outputs for the converter and see if the converter itself is producing DC power or not. If not, make sure the 120v socket it's plugged into has power. If not, check the breakers, cycle each one off and then on and re-check the 120v socket.
If the 120v socket has power but the converter doesn't produce a bit more than 13v, check for fuses on the converter itself.
If the converter produces DC output, measure across your fuse block to make sure DC is available there.
I'm assuming you either don't have battery cables attached at the fuse block, or you made sure the positive cable is isolated to prevent a short before plugging in without a battery installed.
David
DKB_SATX is online now   Reply With Quote
Old 07-07-2013, 08:55 PM   #4
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Also check to make sure you have a good ground. You can also ground out to the body if needed. The bare copper wire could broke at some point.
Silverflames is offline   Reply With Quote
Old 07-07-2013, 09:22 PM   #5
Ill post some pics in the morning
Old 07-08-2013, 09:45 AM   #6
Ok my inverter is plugged in. How do I check to see if power is going out of the unit itself? Please explain it like I'm in grade school. I've never used a volt meter or even a test light.
Old 07-08-2013, 10:07 AM   #7
DKB_SATX's Avatar
1976 Argosy 28
OK, first, to avoid confusion from someone who didn't read this thread from the beginning, or someone you might call from an RV repair place, the thing you're working with right now (PD9155) is a converter (or converter-charger) rather than an inverter.
Looking at a photo of it, I see that there are 2 positive and 2 negative outputs (with a red label above the positive, and a black label above the negative.) Do you have a DC voltage meter or a multimeter? If so, you want to set the meter for measuring DC, and if it's not an "auto ranging" type you want to select the setting for something like 0-20V (that will vary by brand, but you want to pick the lowest setting that has the top of the range at or above 15V.)
Being careful not to let the 2 probes touch (in case they have long exposed areas) touch one probe to one of the outputs with a black label, and the other to one of the outputs with a red label. You can either put the probes on the screw heads that tighten down on the cables, or into the opening where the cables go.
You should expect to see more than 13V while the converter is operating properly.
David
Old 07-08-2013, 10:27 AM   #8
Here are pics if the converter/charger. It only has one positive and one negative output
Old 07-08-2013, 10:46 AM   #9
DKB_SATX's Avatar
1976 Argosy 28
Even simpler, only one to choose from on each side. I see now that even though I searched for photos of a PD9155, I ended up with a photo of a PD9160a (perhaps the current replacement model for the 9155?)
The rest of the instructions are the same, you simply have only one of each output rather than a pair of each.
David
Old 07-08-2013, 11:00 AM   #10
I'm heading to get one now. I'm going to change out my 12v distribution fuse panel for a less complicated AR breaker setup. I'm posting a pic of current panel set up. Notice bottom left the power on white wire is missing. Could this be my problem with exterior lights? If so where can I pull this wire from?
Old 07-08-2013, 11:10 AM   #11
DKB_SATX's Avatar
1976 Argosy 28
You're missing a fuse for one of the primary circuit negatives (the rightmost black cable.) Where does that cable go?
David
Old 07-08-2013, 11:27 AM   #12
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The exterior lights are not powered by the converter. That power comes from the TV. Only the 12 volt devices within the trailer are wired to the converter, via the fuse panel.
If the UCord is wired to match the TV, the exterior lights should come on when you turn on the head lights. Marker and tail lights, that is. The brake and turn signals will flash when you turn on the emergency flashers.
The electric brakes and charge line are also wired thru the UCord as well as the common/ground from the TV.
Old 07-08-2013, 01:05 PM   #13
I have replaced all the fuses. And yes I know the TV supply's the current for those things. What I'm asking is where do I pull that white power on supply from? The panel shows white wire coming in the bottom of that amp fuse and gray wire out.
Old 07-08-2013, 03:13 PM   #14
1971 31' Sovereign
fort myers , Florida
I think a 12 volt battery needs to be in place to pass the 12 volt supply. I could be wrong. That happened once in 1977.
swampthang7 is offline   Reply With Quote
Almost lost in UTAH Zia On The Road... 39 07-06-2011 09:57 AM
lost in long beach newmeguy1 Member Introductions 7 04-26-2011 12:01 AM
Battery lost a cell. Desulfating or refurbishment possible? Keyair Batteries, Univolts, Converters & Inverters 57 02-14-2011 11:26 AM
Would be lost without this forum! AirHome Member Introductions 2 01-30-2011 11:23 PM
