Old 09-25-2014, 09:12 PM   #1
Mantua , Ohio
Odd battery size on a '61
On my 61' Ambassador, I have a battery compartment up front, just below the window.
The MAXIMUM size of a battery(s) is 20" wide, 4 1/2" deep, 10 1/2" tall.
Can I find this size battery and will it/they give me the same power as a normal sized Deep cycle?
Thanks in advance.
Studioman is offline   Reply With Quote
Old 09-25-2014, 10:15 PM   #2
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I bought mine at NAPA. It's NAPA number 7246. It's got a weird group number: 3ET.
I also found it at Interstate battery, but the NAPA had better specs.
Thalweg is offline   Reply With Quote
Old 09-26-2014, 04:11 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I remember the original group was either 2EE or 3EE.
It was a tractor/equipment battery.
Old 09-26-2014, 05:27 AM   #4
Gainesville , Florida
Tractor supply? Jim
Old 09-26-2014, 07:13 AM   #5
Mantua , Ohio
How will these batteries work compared to a "Normal style" Deep cycle?
What is the approx. pricing?
How long will the batteries hold change if just running the water pump under normal toilet use for my g-friend?
Can I use a normal charger for them as well?
Thanks again for your time!
Old 09-26-2014, 07:23 AM   #6
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
It's a Deep Cycle.
I think mine was around $120, but will vary depending on quality. I wanted the highest amp/hour rating I could find.
I've run mine for over a week using the water pump, LED lights, and a little bit of furnace time in the morning when it was cold. Never noticed reduced functionality. When I got home it still had 11.5 volts on it.
You can use a regular battery charger. There are many discussions here about multi-stage chargers. You should read through those. I don't have one yet. I just charge the battery before I head out. I also bring the battery indoors during the winter, and put a trickle charge on it every couple of months.
Old 09-27-2014, 05:09 AM   #7
Mantua , Ohio
THANKS for the info Thalweg! I saw they also make something called a "Power Cell" that is that size, starting around $450 up to $700, depending on needs. I can't justify that. $100 something is PERFECT for me!
Thanks again!
Old 09-27-2014, 06:10 AM   #8
Well Preserved
1993 21' Sovereign
Just some food for thought, if you have a 7 pin connector with a charge line going to the trailer, you can simply take along a regular group 24 deep cycle battery and a $10 battery box, make a plug-in wire connector for it, and feed 12 volt through the 7 pin plug. The 7 wire umbilical only would need the black (+) and white (-) wires connected.
Odd Roof Vent Size and What to Do? 1956Safari Roof Vents, Skylights & Fans 6 04-19-2006 02:08 PM
Furnace odd smell balrgn Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-18-2004 04:07 PM
Odd New Year arrives Janet H Our Community 20 01-03-2004 09:58 AM
Odd skin dents in front and behind axles Mprecure Axles 3 09-23-2003 08:35 PM
Odd VIN Number for Tradewind cherring Title, VIN & Registration 8 08-14-2003 12:03 PM
