Old 06-23-2014, 04:14 PM   #1
1977 31' Sovereign
Cypress , Texas
Question Nubie question on hooking up converter...
Hello all - we just purchased our 1977 31' Sovereign and I'm trying to get the electrical system back up and running...
When we purchased it the Univolt & Battery had already been removed, so I bought a new battery and a Progressive Dynamics (PD9260CV) 60 Amp Power Converter with Charge Wizard.
I followed the AS's service manual schematic and hooked up the battery and the converter, running cable from the converter to the specified spots on the fuse box. I then plugged the AS in, and tested the converter, cycling through the 3 modes and testing the output. All worked great!
So then I unplugged the AS, went back in and tried using the 12v lights and nothing would work. I had to actually remove the copper wires connecting the converter to the fuse box to get the 12v system to work again!? Had I done something wrong? My understanding is that the converter should charge the battery when the AS is plugged into 120, but when unplugged the battery should still power the 12v system without having to do anything.
Am I mistaken? And bare with me if I'm doing something obviously wrong - this is our first Airstream, let alone our first camper period!
Thanks in advance!
Jeffrey
Fireside79 is offline   Reply With Quote
Old 06-23-2014, 06:02 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
First, your understanding of converter operation is correct.
I'm not that familiar with your trailer, specifically, but there was a recent thread on replacing the univolt, and I replaced my converter with the same unit. If I remember the other post correctly, there are two fuses involved, one in series with the converter output and one with the battery. Maybe your battery fuse is blown. If you look at the schematic, can you follow the current path from the battery positive out to a load and back to the negative post? Same question for the converter? You should be able to do the same for the actual battery and converter wiring.
I can't come up with a reason why disconnecting the converter would change the operation of the battery circuit, with one exception. Airstream (and boat manufacturers) often used AC color codes for DC wiring. Standard DC codes would be red for positive and black for negative. AC code has black for hot and white for neutral. So it is possible at when connecting old DC circuits to new you might have to connect old black to new red and old white to new black. Did you, by any chance, connect black to black and red to white?
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 06-24-2014, 12:10 PM   #3
BoCox's Avatar
1969 23' Safari
Raleigh , North Carolina
This is a helpful link. See post #6
http://www.airforums.com/forums/f449...ut-116670.html
Also, it is important to use #6 maybe #8 wire from the battery to the fuse panel on both positive and negative terminals. Use a voltmeter to check the voltage at the fuse panel from the battery. VDC should be 13.6v or so. Using an inferior gauge wire will cause this problem. I learned this lesson once.
BoCox is offline   Reply With Quote
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Trouble hooking gas line to water heater 63air Water Heaters, Filters & Pumps 8 09-06-2005 09:56 PM
hooking up new radio powd Audio, Video & TV 15 07-20-2004 08:37 PM
Hooking Up Trailer Battery to Tow Vehicle flyfshr Batteries, Univolts, Converters & Inverters 11 02-27-2004 10:50 PM
