Old 03-06-2016, 07:51 AM   #1
2016 30' International
Sewickley , Pennsylvania
NOOB - Brand new trailer and dead batteries
Hi guys,
Just took delivery of our trailer on Friday. Towed it home 4 hours to my parents driveway. Drove there yesterday to take a look at it and there was no power whatsoever. We assume the batteries are dead.. But unsure of why as they seemed to have a full charge the day before while connected at the dealer. And, if not, they should've charged on the trip home?? Seems crazy they'd be fully drained in less than 24 hours..
I read some of the threads on this and it's all Greek to me. I guess my question is, if we confirm the batteries are dead, how do we charge them? Can we plug into my parents house electric or no? Will we have to pull them out and hook up to a charger?
More Importantly, once they're charged, what do we do to prevent this in the future?
Sorry... I know these are really stupid questions. We have more mechanically minded friends coming with us to check it out later today. Thought your feedback would help us diagnose. Thanks!!
Eric
Seinbelld is offline   Reply With Quote
Old 03-06-2016, 08:01 AM   #2
1986 31' Sovereign
Miami , Florida
Step one - check that the "use/store" switch is in the "use" position.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-06-2016, 08:14 AM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Step two - read the manual for an overview of all systems.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 03-06-2016, 08:32 AM   #4
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
The same thing happened to me back in July. The use/store switch must be in the USE position to charge batteries when plugged in or being towed. The red light is ALWAYS on when plugged in so if the switch is in the store position your batteries are not being charged even with the light on. Check this by unplugging from shore power, push the USE button then plug back in & your batteries will begin to charge. Also your volt meter will alway read 13+ volts when on shore power as your actuarially getting that reading from the inverter not the batteries, when unplugged you get a true voltage reading. Charge batteries for 24 hours & hopefully they will be ok as mine were, if not take them to shop for a bench charge and see if that helps, if not you need new batteries.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 03-06-2016, 08:48 AM   #5
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
A paper manual? So 80's
AS should produce a DVD, heck they may have.
sgschwend is offline   Reply With Quote
Old 03-06-2016, 09:31 AM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
Plug into shore power and check any of the lights to see if you are charging the batteries. If they are charging check to see if any other light in the trailer is on, this means all the storage cabinets. For the batteries to go dead overnight something was most likely left on.
2004 Excursion 4x4
Old 03-06-2016, 09:38 AM   #7
Long Island , New York
Eric
Hi Eric,
Welcome to the forum! Please report back after you follow the advice so far.
-- plug in trailer to shore power
-- make sure to hit the Use switch (not Store)
-- report battery voltage from control panel
-- unplug from shore power and leave Use switch on
-- report on battery voltage from control panel
When you have time you should definitely read the owners manual, which is also available as a PDF online. When I am back home I will link to it.
Curious to know what dealer you used, and whether they walked you through the trailer's systems thoroughly? You should also call them and have them provide feedback ASAP.
Good luck!
Peter
Edit -- Your 114-page owner's manual is available via the Download link near the bottom of this page:
https://www.airstream.com/service/ma...ear_select=725
Old 03-06-2016, 09:55 AM   #8
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
PM me, I live in Pittsburgh and if you are close I could stop by and take a look to see what is up.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-06-2016, 10:11 AM   #9
Displaced Beach Bum
beachbouy's Avatar
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
Download the PDF version from Airstream. I keep mine on my iPad.
We drag Mitzi a 2016 International Serenity 30 with Goodyear Endurance shoes, with an Equal-i-zer 1000 yanked around with a 2015 GMC Yukon XL SLT 4x4, 5.3L V8 ECOTEC3, 3.92 axle, 6-speed auto WBCCI #6111 AIR #107335
beachbouy is offline   Reply With Quote
Old 03-06-2016, 10:25 AM   #10
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Another thing to check is if the black 12 volt hot lead on your 7 Way Plug from your tow vehicle has power. I have a 2006 GMC Sierra and some do not come with the fuse installed in the engine compartment fuse box for power to go to the 7 Way Plug at the back of your truck.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 03-06-2016, 10:41 AM   #11
2015 27' Flying Cloud
Albuquerque , New Mexico
A couple more things to check is make sure the inverter is off when you do not need it. It will drain you batteries in less than a day if it has been left on unnecessarily. Also the TV antenna booster can drain the batteries but much slower. Good luck
Nmengineer is offline   Reply With Quote
Old 03-06-2016, 11:05 AM   #12
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My batteries will go dead in about 7 days in normal conditions and my pickup will not bring them up much in 4 hours running, plug in at home every week for a day or so and all is fine
Old 03-06-2016, 01:13 PM   #13
2015 22' FB Sport
Ventura , California
check battery with hydrometer
When my girlfriend and I picked up her new 2015 22FB Sport in September everything seemed good during the "walk-thru", although we were connected to "shore power". I failed to examine the battery...it was almost out of warranty. After our first "shake down" cruise in late October I discovered that the battery wasn't holding a charge for very long. Turned out that one of the cells was dead...and the warranty period had expired by that time. I upgraded to a new Group27 after that, and since monitor the battery more closely. I use a float charger and a good automotive/deep cycle charger to maintain. I don't trust the inverter...I think it "cooks" the battery and doesn't provide the proper "float". I suggest you invest in an inexpensive voltage meter to see what the charge rate is at the battery itself when on shore power or hooked to your tow vehicle. Can someone please tell me why Airstream does not put any 12v "cigarette lighter" accessory sockets inside or out? I like to plug in my XM "BoomBox" to 12 volt when were "dry camp/boon-docking". The inside radio works great, but all I see are a couple of USB ports for charging smart phones. Adios!
pablocruise is offline   Reply With Quote
Old 03-06-2016, 01:42 PM   #14
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Welcome to the forums and congratulations on your new AS!
Did you inadvertently leave your electric brake break away switch unplugged after un hitching? That will drain the batteries within a day and may damage the switch.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
Batteries (NOOB) stefario Batteries, Univolts, Converters & Inverters 11 08-27-2009 02:27 PM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
Brand new battery dead in 5 days of use... wavemaster Batteries, Univolts, Converters & Inverters 5 10-14-2006 08:05 PM
