Old 06-09-2015, 11:05 AM   #1
1976 Argosy 26
Dade city , Florida
No power
While working on your 77 Argosy 26 we lost all power. We were plunged into a shore line and I had just turned off the a/c because it was not blowing cold. I have checked breakers and fuses. Also at the same time the water system stopped. At a loss, I can not find a reset button.
Djnole79 is offline   Reply With Quote
Old 06-09-2015, 12:52 PM   #2
Gainesville , Florida
If you weren't plugged into thirty amp you may have damaged the 120 circuits. Others with more knowledge will chime in. Hope you figure out the problem... Jim
Old 06-09-2015, 06:52 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
It is very important you were running your AC with a 30 amp supply. 15 amps can damage the AC due to over heating.
You may have tripped a circuit breaker in the house, or whereever your source of electrical was at the time. Or you may have tripped the breaker in the Airstream.
So check all your breakers. Turn them off, and then back on to reset them. Verify you are delivering 115vAC to your trailer via the power cord. Make sure the AC and other AC powered devices are off or unplugged.
Your battery runs the 12v circuits. If your battery is disconnected, then you won't have 12v power in your trailer. 115vAC runs the converter and powers your 12v circuits even if you don't have a battery. So if you loose 115vAC, you will loose 12v power too if you don't have a charged up battery.
Unless you smelled electrical smoke, you likely didn't damage your trailer (except for the AC if you were running on a 15 amp household circuit.)
If after resetting all the circuit breakers and verifying there is 115vAC to your trailer and you still have nothing, then you gotta start tracing down the problem.
David
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 09:51 AM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
