Old 06-18-2012, 08:49 AM   #1
Brow324's Avatar
2007 27' Safari FB SE
Scurry , Texas
No power 12 V system...stumped.
Last campout was a hot one. During the last day the 30/20 breaker for the lights, a/c thermostat, and stereo kept breaking. Upon arrival home I could not gt any 12v systems to come on, even with shore power connected. So I replaced the 30/20 breaker that had been kicking off all day.
So today the new breaker is in and all 120v systems are working fine but still no 12 v systems are working. No int or ext lights, no stereo, no a/c thermostat, and the battery store switch is not working. Fuses all look good. I checked the battery connections...all good. Unless it's a fuse that is blown under the plastic corner edging and I'm not seeing it I'm stumped.
any ideas? inverter issues?
'07 27 FB - H.A.
Brow324 is offline   Reply With Quote
Old 06-18-2012, 09:17 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Bump
On my Clipper the inverter has two pushbutton reset breakers.
Dave
Old 06-18-2012, 10:06 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
More than likely there is a fuse in the battery output that has blown. You should remove one of the battery terminal wires on each battery and check the batteries. Use a voltmeter of you have one if not just jumper a 12 bulb across the battery with a short wire. If the batteries are good you are then searching for the blown fuse.
2004 Excursion 4x4
Old 06-18-2012, 11:53 AM   #4
Brow324's Avatar
Scurry , Texas
My local RV service guy said that the problem is likely between the batteries and the inverter somewhere since I'm getting 110v throughout and no 12v. Could be a bad inverter but he thinks it's probably a fuse issue. Also need to recheck the fuses to make sure I'm not overlooking a blown fuse that is just hard to see the break.
And need to locate the inverter and the battery output fuse...
07 Safari 27FB
'07 27 FB - H.A.
Old 06-18-2012, 12:14 PM   #5
HowieE's Avatar
Images: 12
The inverter will have input fuses on the 110 side and output fuses on the 12 volt side. There may be a circuit breaker between the inverter and the batteries. That breaker should be a selfresetting type and not likely the problem.
Check those batteries before you go chasing around. No batteries no 12 volts.
2004 Excursion 4x4
Old 06-18-2012, 12:33 PM   #6
Brow324's Avatar
Scurry , Texas
Ok...just checked the AS owners manual on line and the fused/breaker panel is the main access to the power converter and all serviceable areas are there on the panel...there is no reset noted in the manual that I've noticed ...just fuses and breakers. But I'll pull the converter paperwork tonight to be sure.
Also, I'm going to look for a fused connection between the batteries and the converter (which should be readily accessible) and pull the panel fuses relative to my problem and run a continuity check on them for good measure. And will check the batteries too. Hopefully it's something simple. Gotta be since it's the 12V system. Will get back with an update tonite or tomorrow...thanks!
'07 27 FB - H.A.
Old 06-18-2012, 07:02 PM   #7
Brow324's Avatar
Scurry , Texas
after another check here's what I'm finding. Battery power is good. DC current is getting from the batteries to the connection terminal in the front storage compartment where the battery leads connect to a multi terminal and ground terminal then jump to a capacitor looking thing with two blade fuses and a relay attached to it's top. Both of those fuses are good. But I'm not getting DC current coming out of that capacitor looking/relay. What is that? Could it be fried? Or could the relay be stuck? No DC is getting past that to the main breaker panel and all fuses are good at the main panel.
here's a photo of that thing...ground terminal is not in the photo and located lower down on the mounting board out of view. I'm getting current at the connection terminal, on the far right RED connection, but not on the left Red terminal or on either of the Red terminals on that device to the right.
that thing is very difficult to get to BTW and requires me to be completely inside the small storage compartment laying on my backside and working upside down with legs straddling the propane tank mount...ugh...so I'm thinking this might be a good repair for the RV Service center nearby.
'07 27 FB - H.A.
Old 06-18-2012, 07:07 PM   #8
richinny's Avatar
2011 34' Classic
how about a picture?
Ricky
Old 06-18-2012, 07:18 PM   #9
richinny's Avatar
2011 34' Classic
it looks like the use/store relay. i'm sure someone here will know how to test it.
Ricky
Old 06-18-2012, 09:10 PM   #10
HowieE's Avatar
Images: 12
That is an interesting event. It is a solenoid to switch 12 on. Not sure what controls it. Was it part of the solar installation?
Do the 2 fuses on it check out OK?
Disconnect the solar and just attach the 2 heavy red wires if you want 12 volts until you can figure it out.
2004 Excursion 4x4
Old 06-18-2012, 09:38 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Can you follow the large red wire connected to the left side of the solenoid? It is labelled "Battery". I would expect to read 12 volts there with a meter. There must be a switch somewhere to control the solenoid, which would be wired to the smaller (brown) wire on the solenoid.
It is not clear to me what the 2 large red wires on the terminal strip to the left are connected. Can you give us some more info?
Without going back thru this thread and having to retype this. Do you have a battery in the trailer? Is there a battery cutout knife switch that may be open?
Old 06-18-2012, 09:58 PM   #12
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Here's a diagram for the wiring of the battery isolator relay you sent pictures of. There is a push on connector where the wiring harness connects to the rear of the switch panel. The switch toggles the relay to connect or remove the battery/batteries from the trailers internal circuits and converter. The relay needs at least 10.5v to switch from one state to the other. The pair of fuses mounted on the relay assy protect the switch panel as best I can tell as they are only 5a.
In any case, if the relay was stuck in the Store position, the converter would still provide 12v to the interior trailer circuits assuming the converter was functioning and connected to shore power. My suspicion from your description is that your converter is not getting 110v to operate or is not providing dc output and your batteries are run down enough to not allow the relay to toggle to the Use position.
The converter is located in the lower section of the box where you replaced the circuit breaker. It has a fan... At a minimum, you should be able to hear the fan after switching the circuit breakers on. If so recheck your 12v fuses with an ohmmeter. A fuse that looks good may actually fail the meter check. The DC fuse distribution panel is located to the right of the 110v circuit breakers. The row of fuses along the bottom of the board each protect a specific 12v interior circuit. There are a pair of fuses just above them that are in the circuit between the converter and battery charge line and the distribution board. If you have a fuse problem, those would be prime suspects.
If you look closely at that distribution board, you should see 3 lugs and there should be some printing on the board that identify them. One is the 12v common (ground). One is connected to the converter +12v output and the 3rd is the +12v line that goes to the isolator relay and then on to the battery depending on the state of the relay. If the 2 fuses just mentioned are good and the converter is operating, you should see 12v on your voltmeter at both of these 12v lugs.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 06-18-2012, 10:33 PM   #13
2008 27' Classic FB
Burkburnett , Texas
As a fellow Texan with a '08 27 FB, I believe our trailers are wired similarly and I also have experienced the 30a/20a double breaker tripping on hot days. The 30a half is the main line breaker that provides 110v to all the 20a breakers. The 20a half on mine provided power to the A/C. As they share the same housing, the heat generated within the combo causes the breaker to trip prematurely. I moved the line going to the A/C to a different 20a breaker and the lower drawing line to to the 20a half and my breakers stopped tripping on hot days. While you have the shore power disconnected, check each breaker circuit for tightness. A screw that isn't snug on the wire will generate heat that conducts into the breaker causing premature tripping.
AIR 47751
Old 06-18-2012, 10:56 PM   #14
Brow324's Avatar
Scurry , Texas
use/store relay makes sense. However, my batteries are now pretty well drained and only reading 4v now so it's clear that the converter isn't recharging the batteries.
The two fuses on top of the relay check out ok.
HowieE what do you mean by Solar installation? And, are you saying I can bypass the use/store relay (easy enough) and get 12v running to further diagnose?
Silver Goose- I get no reading on any of the lugs at the converter panel. Beginning to wonder if the converter is kaput since it hasn't been recharging the batteries either. Thanks for that breaker wiring tip, gonna do that for sure.
I've got a separate charger on each of the two batteries and maybe by morning I can get the relay to toggle, then maybe get the tongue jack moving, hook up and take to Holiday World in Mesquite to have it fixed since my time is limited this week. And that doesn't get enough 12v flowing to trip the relay I will either have to bypass that solenoid/relay and get some power to the jack or wire directly from a battery to the jack to get hooked up.
'07 27 FB - H.A.
