Old 10-15-2018, 05:17 AM   #1
Dickandvicki's Avatar
1991 29' Excella
Tulsa , Oklahoma
No Electricity
We are camping in Santa Fe and the electricity went off in the middle of the night. There is power at the post, but it’s not on in the trailer. We checked our breakers and they seem to be fine.
Does anyone have an idea what could be causing this power?
Dickandvicki is offline   Reply With Quote
Old 10-15-2018, 06:49 AM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Bad transfer switch? Plug into the front generator inlet and see if it works from there.
Known and common failure point.
Old 10-15-2018, 10:07 AM   #3
1991 29' Excella
Tulsa , Oklahoma
What would cause this?
After the sun came up. This is what we found.
I just talked to a worker at the campground. He said that everyone with “theses boxes” the surge protector had problems. That this campground doesn’t need them :/
Do you think my whole electrical system is damaged?
ID:	325240   Click image for larger version
Old 10-15-2018, 10:59 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
That makes me suspicious of a problem with the campground wiring. Have you tried talking to Progressive Dynamics?
Can you post the name of the campground?
Old 10-15-2018, 11:04 AM   #5
Long Island , New York
^^^^^ x2
If all the surge protectors are causing problems, it is likely a problem with the CG system. Does your PD unit show any error codes? You may have avoided a major problem IMO.
Which CG please. . . Los Suenos perhaps? Saw a review on Yelp mentioning an electrical problem I think.
Peter
Old 10-15-2018, 11:09 AM   #6
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
What is the condition of the plug from your PD to the pedestal receptacle?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 10-15-2018, 11:39 AM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
My first guess would be a corroded or loose connection inside the male plug on the trailer cord.
Looks like two connectors were overheated...the round one is ground, so my money is the other is neutral.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 10-15-2018, 11:53 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
That's just the CG's way of saying... "it's not our fault, it's yours" 😡
Call PD, send pic's if needed.
Do you have battery power?....a generator?
As noted ck the transfer switch...which outlet was used to plug into?
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire.
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 10-15-2018, 11:59 AM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
There is no way the ground pin should have current on it. I'm betting the site has a ground-neutral reversal problem. If not the site, then either the trailer or the surge protector does.
Go to a big box building supply store and buy an outlet tester. They are only a few $. If you don't have one, get a 30A male to 15A female adapter and a 50A male to 30A female adapter. Then plug the stack together to test the campground power before plugging in.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-15-2018, 12:13 PM   #10
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Using the Progressive Dynamics ems, wouldn’t any polarity errors have been disclosed and prevented closing the ems’s contactor? I think Jeff’s suggestion seems likelier, if my guess is right about the ems. But yeah, the cg’s answer is unhelpful at best, and seems likely to be misdirection.
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 10-15-2018, 01:31 PM   #11
Good point, Jim. However, under no circumstances should the ground pin be carrying current. After some research into pin configurations, the two pins that are melted are the ground and the neutral. In my opinion there must be a wiring error (or equipment failure) that has current flowing on the ground and neutral wires and not the hot wire. I just can't figure out what it is.....
But I'm tempted to think the fault actually is in the PD EMS.
Al
S/OS #004
Old 10-15-2018, 01:44 PM   #12
AYRSTRM2's Avatar
1966 22' Safari
1979 30' Argosy
Armada , Michigan
I have seen this kind of damage, but don't have any EMS or other fancy protection systems. When I have seen this kind of damage, it is when water has gotten in between the plug and outlet or other plug end on an extension cord, causing shorts across those pins, and they heat up. Was the electrical cord leading to the plug hot or melted?
AYRSTRM2 is offline   Reply With Quote
Old 10-15-2018, 02:33 PM   #13
In addition to the many good questions and suggestions already, have you used this PD unit before with no previous problems?
Peter
Old 10-15-2018, 05:53 PM   #14
Do you realize that your replies are being posted in your blog?
http://www.airforums.com/forums/blog...kandvicki.html
I always camp where I have electricity happier General Appliance Topics 13 07-27-2007 03:09 PM
Electricity in 1959 Traveler? and awnings? r&kweber 1959 Traveler 8 08-03-2006 11:08 PM
No electricity to the furnace, 69 Sovereign bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-29-2005 07:20 PM
The mysterious world of electricity, or...... krowsea Electrical - Systems, Generators, Batteries & Solar 25 09-03-2004 04:23 PM
Connecting to Electricity ssolid Electrical - Systems, Generators, Batteries & Solar 22 02-12-2004 09:09 AM
