Old 01-25-2010, 11:32 AM   #1
wallybyam's Avatar
No battery power
I'm having trouble getting battery power to my '99 Excella. Everything works fine when on shore power or tow vehicle power but when not otherwise connected everything is dead. Even the indicators on the test panel are dead. The batteries show full voltage when checked with a volt meter. If the on-off switch is bad and not turning on, would shore and tow power still work? I hate to tow it 70 miles to the closest Airstream dealer only to find out the problem is something simple. Any help/suggestions would be appreciated.
Thanks!
wallybyam is offline   Reply With Quote
Old 01-25-2010, 12:18 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
Fuses come to mind first - have you checked them?
You could use your volt meter to see if you have voltage at the fuse panel with the battery switch in the ON position, to see if the switch is connecting properly...
Ray
Ray & Pat; Morada, CA
Old 01-25-2010, 12:40 PM   #3
2005 19' Safari
GLENDALE , AZ
Also, you might check the battery terminal connections; and clean them, if necessary. Just like a car or truck, they can build up corrosion, which can limit the current flow.
Old 01-25-2010, 01:11 PM   #4
wallybyam's Avatar
I did check the fuse panel. It seems that their is no voltage to it. Would shore and tow power still work if this switch is defective? I was considering that a bad switch might be the culprit.
Old 01-25-2010, 03:19 PM   #5
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
Like Pheonix said check connections at battery terminals
arodriguez60 is offline   Reply With Quote
Old 01-25-2010, 03:31 PM   #6
richinny's Avatar
2011 34' Classic
i believe that a bad switch could do that. if the switch internal contacts are corroded, operating the switch a few times might get you a connection. if it then works, you still need to replace the switch. and just for fun, make sure "on" is on and not "off".
Ricky
Old 01-25-2010, 04:26 PM   #7
1980 31' Excella II
Drummond Island , Michigan
With a DC voltmeter or test light check the for power in the DC fuse panel at the Red wire attached to a 50A fuse and the Black wire attached to a 50A fuse. These are the positive and negative wires coming from the battery to the panel. If the test light does not light or slightly more than 12 volts isn't indicated on the voltmeter. Bridge the switch with a jumper wire and check for voltage again. If you have power the switch is bad. If you do not have power I would suspect a faulty ground becuase you said everything worked when hooked up to the tow vehicle. Wiggle Black wires and check connections to the battery and the negative connections in the panel. That is the simple test. If you don't find a simple fix take it to the tech and let them figure it out. 12 volts with a lot of amps can produce a lot of heat quickly and you do not want to fry wiring or start a fire.
Ahzmyrah is offline   Reply With Quote
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Battery to AC power cord??? Jim Casavant Batteries, Univolts, Converters & Inverters 9 07-22-2007 03:46 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
No Power from Battery John Sims Batteries, Univolts, Converters & Inverters 5 08-01-2006 12:02 PM
battery power aeriqua On The Road... 9 02-09-2006 10:46 AM
