05-17-2009, 05:03 PM
1994 34' Excella
Fulltiming
, Out West
No AC power...?
We were sitting here with the airconditioner running when my wife plugged in her new fry pan 15 amps. Within 10 minutes we lost all ac power. All 3 breakers were o.k. but I cycled them just the same and we have ac power coming into the trailer from the line but no ac power IN the trailer...any ideas?
05-17-2009, 05:12 PM
2002 25' Safari
Dewey
Only 3 breakers? My trailer is a lot smaller and older and I have 4. One main for everything and 3 separate circuits. I would double check the main and the one that feed the trailer again.
Sounds like it is time to get the volt meter out.
Richard
05-17-2009, 05:45 PM
Corona
Gotta tell the wife that when she is in the Airstream that she "MUST" limit her power.
Her use of power drawing appliances when the AC is on, that is.
You should find a breaker popped, and the AC usually has it's own breaker.
05-17-2009, 08:05 PM
1994 34' Excella
Fulltiming
, Out West
Thank you Andy and Richard but none of the 3 red and 1 green breakers were popped. I've switched them all off then on again and still nothing. The breakers snap tight both off and on so they seem o.k. I have a Trace inverter which seems to be working at keeping the batterys charged so is that picking up on the 110 shore power but nothing else is?...I will check the breakers with a meter in the morning. Andy are the Airstream breakers difficult to locate or would a napa store be able to order them?....
05-17-2009, 08:16 PM
Corona
NAPA stores are famous for auto parts, not household items such as city power circuit breakes.
Take one with you to Home Depot. They should be able to help you. If not, electrical supply houses can.
But always, take a breaker with you, as a sample.
If all those fail, a couple of Airstream old parts dealers can help.
05-17-2009, 09:21 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
did yo push the gfci reset button on the breaker? if memory serves me correctly, the galley is on that line.
how do you know you have power to but not in the trailer?
did you check the breakers that the trailer is plugged into?
Ricky
05-17-2009, 09:28 PM
2007 25' Safari FB SE
Blaine
My wife did the same thing with her hair dryer when the AC was running. In my case, I not only had to re set the breaker but also the gfci reset button on the breaker and one of the outlets.
John
05-18-2009, 12:29 PM
1994 34' Excella
Fulltiming
, Out West
I found my problem...it seems my Trace inverter has two 30 amp breakers that are small white buttons. One of these was popped out so I pushed it back in and I had 110 shore power again. Sooo even if your breakers look alright be sure to check your breaker on the inverter to see if it has popped. One of our members looked up Trace inverters last night on the internet read all 70 pages of text and called me this morning with the solution. Many thanks to Matt Worner...a real gentleman..........
05-26-2009, 12:15 AM
1987 31' Excella
Oak Harbor
Not able to use shore power
I have an AC power problem when I plug in to power it will blow the 25 amp braker even though i have all inside trailer brakers off and all electrical draw unpluged I checked the wires at RV cord junction box all is good did not see any traces of heat in the braker box also the system can charge my battery could this cause a draw that would trip a 25 amp fuse. (1986 model)
05-26-2009, 03:39 AM
1977 31' Sovereign
Manchester
, New Hampshire
What are you plugging into socket and can you try another plug in item and see if it will produce same problem?
Are you on 30 amp or 15 amp shore power?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
No power
cwagner |
Electrical - Systems, Generators, Batteries & Solar |
7 |
09-19-2007 08:19 PM |
Shore power and battery power problems
jfremstad |
5 |
05-03-2007 08:23 AM |
Too much AC power?
'77sovereign |
Furnaces, Heaters, Fireplaces & Air Conditioning |
5 |
11-29-2006 05:30 PM |
I've got POWER!!
Davydd |
Off Topic Forum |
4 |
09-11-2003 10:55 AM |
More Power
kzener40 |
Mechanics Corner - Engines, Transmission & More... |
10 |
08-07-2003 04:46 PM |
