Old 03-19-2015, 06:02 PM   #1
2018 19' Flying Cloud
Eugene , Oregon
No 12V Outlet?
I may have mistakenly posted to another thread, but I was thinking of getting the samlex 150 watt pure sine wave inverter for my new Bambi Sport 16. However, I can't find any 12v receptacle. Is there not one on the Sport 16? Will I have to install one?
tjwoods1 is offline   Reply With Quote
Old 03-19-2015, 06:07 PM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
There is none but even if there was it wouldn't supply near enough to power a 150 watt inverter.
Al - K4GLU is offline   Reply With Quote
Old 03-19-2015, 06:10 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I don't about the Bambi, but Airstream dropped the 12 volt outlets in the 2015 25FB. They probably dropped them across their line. It was a really dumb idea on their part.
Brian
SuEllyn & Brian McCabe
Old 03-19-2015, 06:58 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The Samlex 150 is designed to be powered by a 12 volt lighter plug. If no receptacle is available you might be able to tap into an existing 12 volt source such as a light. Better yet for any inverter would be to attach as close or directly to the battery.
Amazon.com: Samlex PST -15S -12A 150 Watt DC-AC Pure Sine Wave Inverter - 12V: Patio, Lawn & Garden
MICHAEL
Old 03-19-2015, 07:33 PM   #5
Durango , Colorado
What AWCHIEF already said!
You should wire it directly from the battery.
RVDreamer is offline   Reply With Quote
Old 03-19-2015, 07:40 PM   #6
lewster's Avatar
Naples, FL , Hood River, OR
If you wire anything directly to a battery, be certain to use an appropriately sized fuse or over current device (sized for the wire, NOT the device being powered) within 18 inches of the positive battery connection, per the NEC.
14 AWG needs a 15 amp fuse
12 AWG needs a 20 amp fuse
10 AWG needs a 30 amp fuse
8 AWG needs a 45 amp fuse
6 AWG needs a 60 amp fuse
Larger cable (2 AWG and up) used for inverter feeds need inverter-specific fusing.
12v
How To Install 12v Outlet COArgosy78 Batteries, Univolts, Converters & Inverters 3 07-30-2009 02:01 PM
12V outlet in rear bath of 1979 31' International? wacnstac General Interior Topics 4 06-08-2006 07:23 PM
A new kind of quick connect 12V outlet Westfalia Electrical - Systems, Generators, Batteries & Solar 3 09-04-2005 06:26 PM
12V or 24V outlet for tv John and Anne General Motorhome Topics 3 05-16-2005 12:09 PM
Why do I have a 12v outlet in the lav? TroutStream General Interior Topics 3 07-09-2004 04:59 AM
