Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 06-18-2007, 05:25 PM   #15
Silver Threads
Commercial Vendor
Silver Threads's Avatar
Profile:  1966 24' Tradewind
Kingston , Tennessee
Ok, back again. Didnt help to change the fuses and charge the battery. Still no power on the 12-volt. Any more ideas?
Tammy
John and Tammy Adams
AIR # 15902
Visit our websites, http://www.freewebs.com/silver-threads/
http://restoringour66tradewind.blogspot.com/
Silver Threads is offline   Reply With Quote
Old 06-18-2007, 05:53 PM   #16
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
My 75 TW battery has a plug in the cable so that you can remove the battery without unhooking the cables from the battery. It is located inside the battery area and can cause the problem you discribe. Try disconnecting the cable and connecting it again. Sometimes the connection gets dirty / loose.
If that does not fix it, you will need to meter the voltage from the battery to the 12 volt dostibution panel. You can get a meter at Home Depot for under $20. Everyone should have at least one of these.
Richard
Charter Member Four Corners Unit
Old 06-18-2007, 06:08 PM   #17
pmclemore
pmclemore's Avatar
Profile:  1998 31' Limited
Walkerton , Virginia
I had a problem similar to this - turns out I had a loose connection at the 12-v block going from the batt to the battery isolator switch. If you feel the 12-volt connections, one or more may be very hot. Tighten the nut and reset the disconnect and you may get lucky.
Pat
pmclemore is offline   Reply With Quote
Old 06-18-2007, 06:09 PM   #18
Silver Threads
Commercial Vendor
Thanks Richard. He tried unplugging and replugging. I guess its a trip to Lowes now! Will update shortly!!
AIR # 15902
Old 06-19-2007, 07:42 PM   #19
Silver Threads
Commercial Vendor
Ok, checked all the fuses and replaced the two that were bad. We bought this battery on 7 April and had assumed that it was not the problem. Been raining here and just now got out to check it, and it is dead. I believe it is shot as my charger will not charge it.
We had the camper plugged up here for quite some time since we got the new battery. Could it have been overcharged and ruined from being plugged up too long?
According to the manual, the univolt shuts down when the battery is fully charged????
I feel rather stupid for not checking the battery sooner!
AIR # 15902
Old 06-20-2007, 10:55 PM   #20
azflycaster
Phoenix , Arizona
Images: 58
If your UniVolt is the original unit I would say yes. They can over cookthe battery. One sign of this would be if the cells are low on water.
Richard
Old 06-21-2007, 07:23 AM   #21
Silver Threads
Commercial Vendor
Actually, I never did let the battery run low on water. I usually check the water level every 2 weeks. I had the battery on the charger for about 3 hours, but still nothing!!
AIR # 15902
Old 06-21-2007, 02:23 PM   #22
azflycaster
Phoenix , Arizona
Images: 58
It's only a few months old, take it back, get a new one! Also, if you are going to leave it plugged in for loooong periods of time, get a new convertor. One with 3 stage charging. If you use an old univolt for loooong periods of time, you see what can happen.
Richard
Old 06-21-2007, 02:33 PM   #23
Silver Threads
Commercial Vendor
Yes, we are going to take it back and get a new one. Another lesson learned!!
John
AIR # 15902
Old 06-21-2007, 02:56 PM   #24
rickandsandi
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
John,Everyone has given some really great advise, and I am sure I have read several threads here on the old univolts frying batteries. While restoring the Tradewind the first thing to go was the univolt. Run a search on the forum on univolts and I think you will find most will say to disconnect the univolt once the battery is charged.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is offline   Reply With Quote
Old 07-03-2007, 05:30 PM   #25
ColdEspresso
Riviting Espresso
ColdEspresso's Avatar
Profile:  1978 25' Caravanner
Nashville , Tennessee
No 12v power
I am in a similar situation. I have a new univolt that was installed last in my 78 Caravanner at JC along with 2 new Interstates. Fuses are fine but still no 12v. All is fine when I am plugged in but once I unplug, nothing. Is there anything I am missing?
Mario & Kelly (and Missy the Smooth Coat Collie)
Music City, USA
AIR# 12509
1978 Caravanner
2002 Chevy Avalanche Z71
2005 Volkswagen Touareg V8
Rancilio Espresso Machine w/ Rocky Grinder
ColdEspresso is offline   Reply With Quote
Old 07-03-2007, 06:27 PM   #26
Silver Threads
Commercial Vendor
We have found out that it was the Univolt frying the battery. we have went through 2 before we figured it out though. Good thing they have warrenties,lol! Back to Wally World to trade it in!
AIR # 15902
Old 07-03-2007, 07:15 PM   #27
ibgl6
ibgl6's Avatar
Profile:  1973 27' Overlander
Southport (Panama City) , Florida
I got the other problem no 12volt when battery is disconected 110 works just fine but nothing as far as lights ect without battery????
Your Friend Sam In (Southport) Panama City Florida Air#15607
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 07-03-2007, 07:36 PM   #28
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Exclamation Frying the Battery
Hi John and Tammy,
The univolt in my 67 boiled the battery one night. My Carbon Monoxide (CO) detector woke me in the middle of the night. My fridge was running on propane due to a corroded connection at the thermostat, and I at first thought that some strange wind had forced the exhaust back into the coach. After through ventilation dropped the CO levels to zero, I closed the coach. Alarm in 15 minutes! Point, a CO detector is vital, even if you have the propane shut off.
On another note,
Originally Posted by overlander63
Tammy, it could simply be a dirty battery cable end. The Univolt was supplying power to the 12 volt stuff while it was plugged in, and when you unplugged it, away went the power. The load of several lights caused the battery to lose connection. So, check the battery cable ends and connections to the battery before going crazy looking everywhere else.
Terry makes an excellent point. Not only could the battery cable be corroded at battery connection, it could be corroded anywhere. I had corrosion on the Bakelite fuse connector that required replacement of it and its associated wires.
Vaughan
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
power boosters John Our Community 18 11-19-2002 03:54 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
no power Mike Electrical - Systems, Generators, Batteries & Solar 10 08-20-2002 06:38 PM
