Closed Thread
Old 07-04-2012, 02:49 PM   #85
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
While reading this thread camping , our trailer lost power. At the time of failure we were using the AC, had microwave plugged in but not running, refrig on electric,and the water heater on electric and the 30 amp breaker tripped. After flipping the breaker and turning off the water heater all is well. I now know that I was overloading the 30 amp breaker but did did the system perform as expected?
At the Bash
Gary
Castaway is offline
Old 07-04-2012, 02:57 PM   #86
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yep....
That's the way ours werks, and we don't have the ATS.
The results of an overload condition SHOULD be the same for both.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
ROBERT CROSS is offline
Old 07-04-2012, 04:29 PM   #87
Gainesville , Florida
Redwood, Yes I do. However repeating what some would say could be misleading info, may lead some to interpret the info without questioning it. I am not saying the switch is bad, but the remedy may be premature. Jim.
xrvr is offline
Old 07-04-2012, 05:05 PM   #88
2012 25' Flying Cloud
Eureka , California
I read that (because it was addressed to me), but I don' t know what any of it means.
redwoodguy is offline
Old 07-04-2012, 05:09 PM   #89
your question at the end of post 81, jim
xrvr is offline
Old 07-04-2012, 05:42 PM   #90
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
30 amp breaker might not trip at 30 amps. Basically the purpose of the breaker is to protect the trailer wiring and keep it from burning when there is a dead short. I do not think breakers are real accurate. After reading all this I am not going to put in a ATS any time soon. The OP probably needs a bigger or better ATS or to take his out and put in a manual switch for the way it is being used. Which is what I think he said upfront. I do not expect Airstream to replace it with anything but another one like the first. Maybe the ATS has some sort of built in overload protection to keep it from frying since it is in front of the 30 amp breaker. there is probably no fuse or breaker protection between it and the power source? I can see nothing wrong with putting a 50 amp ATS or a manual swich in since that part of the circut is projected by the campground breaker, just like the cord is. One thing about heavy and quality electrical components is that they are expensive. I really find nothing wrong with the addition of a 40 amp fuse in front of the ATS. After all, it is just replacing a piece of solid wire. Not sure I see any use in it either. Personally I like the manual switch or the long cord approach myself.
Bill M. is offline
Old 07-05-2012, 07:13 AM   #91
I just called the Airstream Free Technical Support Line and left a message regarding the repair of my non-cooling air conditioning, tank monitors DOA, and no power when the breakers are not tripped. The web site states “This is a voice mail system only. Your call will be returned within 24 hrs”
The recording stated that a "response will be within 24 to 48 hours". Here is another I had no idea but I am not going to comment on what I think about this level of customer service as I don’t want to continue to be seen as one of the "handful here who pile onto every problem with incredible enthusiasm". I'll wait to see when factory service gets back to me and hopefully it will be sooner than 48 hours.
mtntime is offline
Old 07-05-2012, 07:53 AM   #92
Eureka , California
Originally Posted by Collimare View Post
tank monitors DOA,
Do you mean you get no lights at all. Or, do you mean the readings aren't accurate?
Here's how mine works for gray:
It indicates 1 bright LED and 1 dim LED until the water is coming up out of my shower. At that point is reads all 10 bright LED. (But of course, I hear the gurgling in the shower first as my "audible" tank monitor.)
The battery always shows full no matter how it is used. I take no chances with the black.
Old 07-05-2012, 08:08 AM   #93
1988 25' Excella
1987 32' Excella
Could be they are off for the 4th July week. Lots of companies do that. I would not count on them until next week.
Bill M. is offline
Old 07-05-2012, 08:08 AM   #94
They were not accurate at all. With my wife yelling from the shower that the tailer was flooding I checked the monitors again as I had been and the grey was still showing two green as I recall. The same thing after I emptied it. I did not bother to check any further.
mtntime is offline
Old 07-05-2012, 08:38 AM   #95
Goal15's Avatar
Dallas , Texas
Collimare:
you might want to read this thread with reference to the grey water in the shower.
It seems that its not always a sensor issue but may be a plumbing vent issue as well
http://www.airforums.com/forums/f444...sue-83758.html
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline
Old 07-05-2012, 09:09 AM   #96
I am not trying to pile it on but post it here to demonstrate what I see as systemic poor quality on the part of Airstream. This is very indicative of Harley Davidson before their turnaround back in the mid to late 80s!!
I mentioned that on top of coming home early due to the power issues I had a flat on the way. Thankfully it was while we were having breakfast in Frisco, CO. It was no fault of the tire as it appeared to have a puncture, however when I got the spare down I was concerned about the condition of the brand new tire. It may be hard to see in the photo but in one spot on both sides there was a good deal of rippling of the side wall/tread wrapping around to the opposite side. I also could not get the thin wall deep socket to go on the lugs. I was sure I put the right socket in the truck so proceeded to tap it on to the lug. Got the lug off but could not get it back out of the socket so I put it back on the stud and finally got it to come out. In looking at the lug nuts they are very cheap nuts with a pressed on fake chrome covering over the actual nut. All of the lugs showed some amount of splitting making it hard to get the socket on and the nut out. The new lug on the left is the same size as the defective one on the right just the camera angle trying to show the split. I had already been planning on replacing the tires and this just hastened the process. I took the wheels to Costco and had them put new Michelin LTX M/S2 235/75R15 on filled with nitrogen per forum recommendations, my preference as well (shown at bottom). I also bought all new solid chrome lugs ($14 for all 24) to replace the cheap/defective ones from the factory.
After a bit more research the Parallax ATS/Single Stage Controller in my 2012 is the cheapest one made that will do the job, and in my opinion it is not. This is the same controller sold in every other low end similar size 20-30k travel trailer. Parallax has a mid-level 2 stage unit available, and there are much better ones like the 3 stage IOTA DLS-55/IQ4 that I plan on putting in after Airstream replaces my current bad Parallax ATS/Controller. This also seems to the case with the Air Conditioner as well. I am told it cannot even be recharged or serviced as it is a throwaway. Why would I go to all the trouble to research and upgrade a brand new trailer I paid 60k+ for?? Because I thought I bought a premium product, that was reliable!! and have every intent of making it one. For those who are satisfied with the level of quality put into their trailer, or are willing to live with it, my hats off to you, but why berate those of us who are not. Why should I wait 24-48 hours for Airstream to get back to me to replace the defective units with the same bottom of the line components. Don who started this thread is on his second (2nd) AC unit and waiting for his third (3rd) ATS/Controller hoping for a good one! I will also play the game but plan on upgrading most of the important parts of the trailer as I noted earlier.
Ponder that if everyone keeps accepting it, it will only continue to get worse guaranteed!
I am sincere that anyone considering buying what they think is a high end premium product should be fully aware of the facts as I wish I had been!
To each his own and best of trailering wishes.
ID:	162410   Click image for larger version
Name:	New Trailer Tires.JPG
mtntime is offline
Old 07-05-2012, 09:46 AM   #97
AS was closed for the holiday. Jim
xrvr is offline
Old 07-05-2012, 09:48 AM   #98
Eureka , California
The lug nuts too? This is just a pitiful, shameful and embarrassing testimony to "Made in America." I think I am going to go vomit.
Closed Thread
