Old 10-18-2007, 12:41 AM   #1
1974 29' Ambassador
1971 31' Sovereign
Klickitat , Washington
Newbie needs help with electrical system
Just got my 74 29' Ambassador, and I'm having old trailer issues, both electrical and plumbing. This is the electrical issue.
The battery apparently gave its all during setup - the jack worked, and I had lights for a little while. Then, nada. I replaced the thoroughly dead battery, and now have lights. What I can't figure out is - when I'm hooked up to shore power, the 120 outlets work, but the ceiling lights don't. When I'm not hooked up, the lights work, but the outlets don't.
The original univolt has been replaced with a magnetek unit. I can hear a low hum from it, much like an aquarium pump, but how do I tell whether it's working properly? I don't trust the control panel at all, the meters don't seem to change no matter what is going on.
jacqueg is offline   Reply With Quote
Old 10-18-2007, 04:35 AM   #2
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
I'm very new at this myself, but I think I can solve one of your problems. The "univolt" just converts 110volt to 12volt. Your 110volt outlets will not work unless you are plugged into shore power.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 10-18-2007, 06:38 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome to the Forums. We're glad to have you with us.
It sounds like your converter is either not operating properly or was not wired right when installed. First, I would try checking the wiring to and from the converter using the installation instructions.
SuEllyn & Brian McCabe
Old 10-18-2007, 09:05 AM   #4
Central , Mississippi
I'm with Moosetags. I'd start with the added charger because the factory setup won't act like you describe. If the 12v lights work with out 110, adding 110 shouldn't do anything except maybe make them brighter. Kinda sounds like the new charger has some kind of bypass in it .
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-18-2007, 03:49 PM   #5
1974 29' Ambassador
1971 31' Sovereign
Thanks moosetags. It's possible the PO left the instructions in the trailer, I'll look. If that's not the case, I guess I'll have to see if I can figure out the model number of the magnetek and see whether I can get a copy of the instructions. Any cautions should I have to do the trial and error thing?
HiHoAgRV, when you say charger, is that a synonym for converter, or are they different gadgets? And why would someone install a bypass in the electrical system?
Thanks for your responses, I've never owned an RV of any kind before. (Personal note - I saw my first airstream when I was 3, and have wanted one ever since. I'm not saying how many decades!)
Old 10-18-2007, 04:16 PM   #6
Can-O-Pabst's Avatar
1964 17' Bambi II
Silverton , Oregon
Here here! When I was growing up I remember an international rally in my home town, the blinding reflections went on for what seemed to be infinity. Ever since then every time I saw an airstream on the road I started to drool a little. From what I understand my wife had similar experiences growing up, I'm just excited that we have one now, even if it's going to take a million hours of work to make it what we want.
Cheers and best of luck with your new baby.
Can-O-Pabst is offline   Reply With Quote
Old 10-18-2007, 08:30 PM   #7
I tend to say charger instead of converter because the words COnverter and INverter get swapped and are not the same.
The easiest way to understand a basic system is the 12v battery runs the lights and the converter (charger) uses 110V to keep the battery from dying. Of course there will be some exceptions but all the units I have ever dealt with operate this way. I can not come up with an example that would match your issues unless something is installed really wrong, like the converter wired to the battery positive to negative .
Where it gets confusing is when we toss an inverter into the system. It takes 12 and inverts the process into suido 110v (and in most cases, quickly depleting our batteries ). Then we get really confusing by incorporating the charger(converter) into the same unit as the inverter
No, you can't use the inverter to run the converter to keep the batteries charged while you use the inverter... I'm dizzy
Old 11-29-2007, 04:00 PM   #8
1974 29' Ambassador
1971 31' Sovereign
It turned out to be a loose connection. So now when the 12v lights die, I just burrow into the closet and jiggle the wires a bit. Presto, lights.
The loose connection appears to be somewhere in the magnetek itself. A replacement is clearly in order, but not right now - too much other stuff going on!
Thanks again for your help.
Electrical system 101 pinkflamingoes Batteries, Univolts, Converters & Inverters 12 12-14-2007 12:18 PM
electrical system crowldawg Batteries, Univolts, Converters & Inverters 6 09-27-2007 09:36 AM
'53 Cruiser Electrical System amron Electrical - Systems, Generators, Batteries & Solar 2 02-14-2006 12:49 PM
Electrical System Basics 66 Tradewind Electrical - Systems, Generators, Batteries & Solar 5 10-19-2004 06:24 AM
electrical system diagram duckrunner Electrical - Systems, Generators, Batteries & Solar 3 10-22-2003 07:53 PM
