06-06-2009, 12:15 PM
Stockbridge
, Georgia
New Xantrex, New battery, no power, GRRRRR!
I just replaced my old Uni w/ a 60a Xantrex w/ a new battery and I still have no power for my overhead lights! HELP PLEASE! All my fuses are fine, ac breakers fine too, what am I missing? When I plug in from the house I have only wall sockets working no overhead lights, and the fan on the new converter won't turn on. :confused HELP Anyone?
06-06-2009, 01:15 PM
2007 23' Safari SE
San Diego
You might go back and make sure you have hooked up the Xantrex converter correctly, reset the circuit breakers and make sure the battery disconnect switch is on or "in use" position.
See Ernie's article, " Parallax 7355 Converter Replacement with Xantrex XADC-60". He noted in his last paragraph that he forgot to turn a circuit breaker back on.
Also see my installation of Xantrex in my post, " Parallax Converter Replacement with Xantrex"
06-06-2009, 02:07 PM
Las Vegas
, Nevada
Does this mean your overhead lights were not working before the replacement?
06-06-2009, 02:09 PM
Stockbridge
, Georgia
The AC breakers are on still no power. I'm stumped. or stupid depending on how you look at it.......
06-06-2009, 02:21 PM
2002 25' Safari
Dewey
If you have 12 volts on both sides of the 12 volt fuses, but not at the lights. I would check to see it the 12 volt ground line (negative side of the battery) is connected to the frame of the trailer.
Richard
06-06-2009, 03:34 PM
Stockbridge
, Georgia
the overhead lights were working before until the new battery died even w/ it hooked up to shore line (house), then I got the new converter & another new battery.
06-06-2009, 04:03 PM
Stockbridge
, Georgia
I'm going out to check the ground wire from the battery now.
06-06-2009, 04:38 PM
Stockbridge
, Georgia
The ground wire is connected to the frame.
06-06-2009, 07:30 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
is the breaker for that outlet on a gfci breaker and if so, did you push in the gfci button to check and reset it?
Ricky
06-06-2009, 11:49 PM
Stockbridge
, Georgia
sorry for the taking so long to reply, almost forgot about "Date Night" !!! Anyway the outlet is not on a GFCI, just a old fashioned outlet.
06-06-2009, 11:54 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
your negative cable is fused also.
check that.
john
you call them ferrets, i call them weasels.
06-07-2009, 08:18 AM
2002 25' Safari
Dewey
I would use a volt meter to find the problem. Attach the negative meter lead to the frame/interior skin of the trailer and see where you have +12 volts and where you do not. Start at the 12 volt distribution panel and go from there.
I still think you may have an issue with the grounding of the trailer.
Richard
06-07-2009, 08:46 AM
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
You should also check to see if you have +12 volts coming directly out of the Xantrex converter. If the fan isn't coming on, maybe its not getting power so also check the shore power supply feeding the Xantrex.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
06-07-2009, 12:05 PM
Stockbridge
, Georgia
Found the problem!!! #1 grounding: pinched behind interior skin.
#2 fuse: 50A glass fuse was blown at the bottom of the fuse, not
in the middle.
Lesson learned? Yep!! Thank you for all, your help & expertise is truly appreciated.
Now all the overhead lights are working, no smoke, no spark, no fire, feeling pretty good thanks to you guys!
Now, is the fan supposed to come on & stay on all the time or only as needed?
06-07-2009, 12:10 PM
2002 25' Safari
Dewey
Glad to hear that you are out of the dark!
I'm not sure about your unit, but the Intelli-power 9245 fan in my trailer only comes on if the temperature gets high or if I have a large load on it.
I can make the fan come on by turning on a lot of lights in my trailer. I have around 30 bulbs total, the fan comes on after I light around 20-25 of them.
Richard
06-07-2009, 05:23 PM
Stockbridge
, Georgia
I have the XANTREX 60 amp, haven't really put a load on it yet but I'll keep an eye on it.
06-07-2009, 07:43 PM
2007 23' Safari SE
San Diego
...Thank you for all, your help & expertise is truly appreciated.
I have the Xantrex XADC-60A unit and the fan comes on only when needed (when a load is placed on it). A bonus, though, is that the fan is quieter than my previous Parallax converter.
Glad you found the problem and thanks for posting about it.
06-07-2009, 09:40 PM
Stockbridge
, Georgia
i think I spoke too soon! I got lights but they only last about 3 hrs., even with the it hooked up to the house. Its late, I'll try again tomorrow after work.
Nite All
06-07-2009, 11:44 PM
2007 23' Safari SE
San Diego
Right... well, check the fuses again... and if it is the same fuse that blows, you will have to figure out why it is blowing...
As others have mentioned, use a voltmeter to check all connections... also make sure you have correctly connected the Xantrex and provided adequate grounding for it as mentioned in the article that I linked to you.
(I am assuming you have proper 30 amp power supply from the house.)
Good luck and please keep us informed.
06-08-2009, 11:34 AM
Stockbridge
, Georgia
I'm going to go home & check my home power supply first, get a volt meter & then get back to work on it. My theory is, since I know nothing at all about 'lectricity, is you are probably right, my house power is not 30 amp. I'll keep you posted.
