Old 04-06-2015, 10:34 AM   #43
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
My two Interstate 27s with a manufacturer date 3/13 while hold a charge don't seem to have any capacity left. When I purchased my preowned 2008 Classic 25fb the converter didn't seem to be charging the batteries. I took it back to the dealership (AS dealer mind you) and all they ended up doing to putting in new Interstates. Thinking the issue fixed I went out on the weekend to a campground with electricity and found the batteries running low to where even the LP leak detector was indicating too low voltage. I went out and bought a battery charger in the town closest to the campground and put the batteries on the charger but I think the batteries may have been damaged.
Then last year I determined the tow vehicle wasn't charging the batteries while towing. I traced the 12v wire as it entered the trailer and it went straight to the hydraulic brake actuator. I ended up connecting the black wire from the trailer harness and the power wire from the brake actuator to the 12v positive bus next to the Store/Use relay.
I took the batteries out this winter and checked the cells with a hydrometer and found two cells specific gravity low. I put a 15v charge on the battery and the cells seem to have recovered. I left the batteries on a smart charger for a couple of months. This weekend I put the batteries back in the AS and went camping. The site had electricity and I have a PD 4655 3 way converter. It charged the batteries for two days.
When I returned home I dumped and checked the battery voltage while at the dump station without the TV running and it showed 12.8v. Then drove home about 45 miles. When I finished parking the AS in storage I checked the batteries and now they are 12.6v. So from the time I left the dump station at the campsite to home it went from 12.8 to 12.6. The ambient temperature was in the 50s. I turned on the overhead lights where are converted fluorescent to LED strips (2 12" strips in each light) and noticed the voltage down to 12.2v. Not sure why so much drop. The only appliances running and the trip home was the fridge circuitry and the LP leak detector.
I have the LP leak detector 12v wired so when the Store/Use switch is on Store the leak detector is off.
With two batteries with a total of 160 amp hours I can't believe a few LED lights can draw down the voltage from 12.6 to 12.2 or am I wrong?
I have a trip out west in June and a couple of campgrounds have no hookups so I'm wondering if I should replace the batteries. I don't think I'll go with AGMS due to price and weight and continue to use flooded grp 27. I'll probably try another brand instead of Interstates.
Kelvin
Old 04-06-2015, 06:01 PM   #44
lewster's Avatar
Naples, FL , Hood River, OR
Kelvin
Kelvin,
If you want to stay with flooded cells in the group 27/31 range, look locally for a Trojan battery dealer. For flooded cells, they seem to be the best in their class.
BTW, how did you have your 27's oriented in the battery box? I have a new solution for mounting 27/s and possibly 31s without ANY box modification. PM me if interested!
Old 04-06-2015, 11:18 PM   #45
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
I just bumped into this thread......
We are beginning our search for good replacement batteries in our 28' FC. Anyone got any recommendations ? We just changed out the inventor / charger to a multi-stage unit, so that end of things should work better for the new batteries also.
Thanks in advance for any input
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 04-07-2015, 09:05 AM   #46
KJRitchie's Avatar
2008 25' Classic
I'm able to mount my grp 27 Interstates so they are aligned 90 degrees to the center line of the trailer. I don't have to remove the threaded hold down rod either. I put the first battery to the back of the box behind the threaded rod. The next lowers straight down into the front of the box. I find it easier to do this with the propane cover and tanks removed. I'm not sure if the previous owner had done anything to make this happen. I can't tell if the lid has been modified. Maybe this orientation doesn't work for other models.
I went and looked at a local battery dealer in Springfield, MO that sells batteries. They have the Trojan 27TMX. They quoted me $140 ea. 105ah at 20amp rate and the specs state they weight 55lbs which are only 2lbs heavier than my Interstates.
They also carry their own brand of RV batteries including AGM. Grp 27 is about $220 100ah but they seem heavier than the Trojan probably 10lbs more. I believe they are made by Johnson Controls.
One thing on the spec sheet for the Trojans is the absorption rate is 14.8v but my PD 4655 converter/charger absorption voltage is only 14.4v. Will that be a problem? If it is maybe I should buy their deep cycle brand. its about $45 cheaper. My understanding at lower voltage rates will never completely charge the battery which causes it to slowly decline. All the Progressive Dynamics inverter/charger modes use the Charge Wizard feature with absorption rates of 14.v, normal mode 13.6v and float 13.2v.
Kelvin
Old 04-07-2015, 09:32 AM   #47
Arcticfox's Avatar
Central , Canada
Further to my post above. I thought I would mention that my (guess) on needing new batteries is based on plugging my trailer into shore power for a few days and let the inventor/charger do its thing and charge the batteries....
At the end of the charge I plugged a little battery meter into the cigarette light plug in the trailer and it told me the batteries were putting out 12.5v Then let the trailer sit all night with the switch in storage mode and this morning I plugged the meter in again and today its reading 6.5v.
so with this in mind i'm guessing my batteries are not holding their charge and intern need to be replaced.
Does this sound correct?
Doug
Old 04-07-2015, 09:34 AM   #48
Airstream Dad's Avatar
2005 28' International CCD
Arlington , Virginia
Re-bumping this thread, the batteries in my 2005 International CCD died, need to replace them.
Advice on the best replacements? Presumably a high quality AGM deep cycle battery, recommendations on specific brands appreciated.
Best
Airstream Dad
Airstream Dad is offline   Reply With Quote
Old 04-07-2015, 09:48 AM   #49
KJRitchie's Avatar
2008 25' Classic
Lifeline, Trojan are two name brands. Trojan offers an AGM as well as flooded 6v and 12v grp 24 and 27. If you have the single stage inverter/charger then you may not want to put the money into AGMs. You really need to invest in a decent 3 or 4 way inverter/charger that will match the AGM charging specifications. See my post #46.
Kelvin
Old 04-07-2015, 04:55 PM   #50
Arcticfox's Avatar
Central , Canada
Thanks for the info Kelvin - I changed out my inverter/charger last month with DLS-55 3-stage charger. Now its time to go our and see what batteries cost...... ouch.....lol
Old 04-07-2015, 06:53 PM   #51
lewster's Avatar
That's a CONVERTER/charger that you have. DLS55-IQ4 from IOTA.
Old 04-07-2015, 08:50 PM   #52
Arcticfox's Avatar
Central , Canada
Thanks Lew - Yes your right. I just purchased what was recommend as a replacement for the stock unit that came with the trailer. Does this impact the type of battery I should be purchasing? I tried again to charge both batteries and one seems to charge up just fine with 13.66 after fully charged according to my Multi Meter. The other one not so good as I can only get it to go to 11.66 out of it. So I'm assuming that one might very well have a dead cell. At least that's what it looks like from what I have read on the net.
As yo can tell I don't know the first thing about these things so any help would be great.
Doug
Old 04-08-2015, 03:12 AM   #53
lewster's Avatar
Sounds like one is bad, which would require both being replaced. Every battery has different voltage requirements for proper charging. ANY converter is a compromise, as they are 'one size fits all' solution to widely varying charging parameters, so you will not get EXACTLY what a specific battery requires.....just close enough to approximate it's needs. The BEST solution is a fully programmable charging system like those found in quality solar charge controllers of Magnum INVERTER/chargers.
Old 04-08-2015, 05:48 AM   #54
Arcticfox's Avatar
Central , Canada
New Replacement Batteries
So with this in mind, am I best to stick the interstate battery of head a different direction?
Doug
Old 04-08-2015, 06:22 AM   #55
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
search interstate batteries issues on google.. most of the boat living people do NOT use interstate batteries.. they use trojan golf cart batteries or the more expensive models, mostly 6 v size, which are a better product and provide longer life with more voltage over the same time frame.
plus changing out to a good mangum type system with a bogart Trimetric TM-2030-RV meter will give the best of both worlds is the wiring is sized properly, which in most cases is NO...
http://tinyurl.com/nempghp get the 500 amp shunt
Doug
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 04-08-2015, 06:41 AM   #56
lewster's Avatar
You don't need a Trimetric if you have a Magnum. You can install the integrated Magnum BMK-N battery monitor system that reads they the ME-RC remote.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Need new batteries jvbak Batteries, Univolts, Converters & Inverters 7 09-29-2008 10:03 AM
Batteries SJ Brown Batteries, Univolts, Converters & Inverters 9 06-17-2008 05:59 PM
batteries dsmith Electrical - Systems, Generators, Batteries & Solar 7 03-15-2006 07:36 AM
Batteries 85/345 Mechanics Corner - Engines, Transmission & More... 30 01-28-2005 04:47 PM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
