05-06-2007, 06:17 PM
1979 31' Excella 500
Detroit Area
, Michigan
New Progressive Dynamics convertor, AGM battery, and Pendant questions
Hi,
I've recently upgraded up electrical system. I bought the AGM G27 size battery, then I went and upgraded by convertor to a INTELI-POWER 9200 SERIES and got the remote pendant with it. Those who have read my posts on these forums before know that I am permanently boondocking and use only a generator for charge and use the battery when I don't want to run the generator.
Now some questions. I got the system all hooked up. Stuck my charge pendant up where I could see it above the fuse box. The LED indicated went from solid to fast blinking, to a very short blip of a blink as I would expect as the battery was charging. Everything seemed to be A OK. I also put in a nice new digital voltmeter which was calibrated for most accuracy right around 12.5 volts.
Now for the weird part. It was a cool night so I went to bed and set the furnace for about 55 degrees. I noticed that even though I had disconnected the trailer from AC the pendant was still on and showing a solid non-blinking LED. I didn't think anything of it at the time, but should the pendant even be on when no AC is going into the convertor? When I went to bed the system voltage was right around 12.6-12.7, so I thought I'd be in great shape. About 4 in the morning I woke up freezing. The furnace had not yet come on so I thought I'd be in great shape with the battery. Just kick it up a notch. I looked at the system voltage and to my horror saw it was just 11.9 or so. I reluctantly went outside and started the gen to run the furnace. The pendant showed solid green until I stopped running the generator at about 9am.
Later, I put an ampmeter between my battery and the rest of the system. With everything turned off there was maybe 20ma of load. I had someone turn on my furnace. To intially kick the blower over it takes somewhere around 10A and then a steady current of 6.8 amps (well within the ranges I've heard here).
So I can't understand why I'd wake up with a discharged battery and second I need someone to explain that pendant to me. Should it show anything with no AC? If you hold the button down to manually go through the modes, how do you make sure it is back in full auto mode?
Steve
05-06-2007, 06:43 PM
Tramp Streamer
1995 28' Excella
Artist
, at Large
Hi Steve,
My pendent also blinks when not connected to AC.
Not sure about your other issues.
Best,
Michael
05-06-2007, 07:02 PM
Naples
100% SOC=12.80 volts or greater 75% SOC=12.55 volts 50% SOC=12.20 volts 25% SOC=11.75volts 0% SOC=10.50 volts
This table ( it WAS a table when I copied it!!) shows you the state of charge at certain volts for Lifeline AGM batteries. At 12.6 volts, you are at about 80% capacity. A Lifeline AGM GLP-27 battery should provide you with 655 minutes of constant discharge at an 8 amp draw for 655 minutes FROM A FULLY CHARGED BATTERY.
Most RV components will not function below a certain voltage. It varies with each component, but they vary from 11.0-11.5 volts before they just won't work due to low voltage.
If you assume that you lose 20% on the top end due to an incomplete charge (13.2 volts is more like a full charge, or 2.2 volts/cell), and another 25% on the bottom for the voltage threshold, that leaves you with roughly 50% of battery capacity that's useable, or 325 minutes at 8 amps, or 5 hours. Subtract any parasitic loads and start-up amperages that are there and you'll be down to maybe 3.5 hours.
Depending on the cycle time of your furnace, you could have easily reached this point.
lewster
05-06-2007, 07:10 PM
Detroit Area
, Michigan
Does anyone know where this table is? I thought 12.7 was fully charged with no load.
05-06-2007, 07:32 PM
Jupiter
Who is the manufactuor of your battery? Lifeline was mentioned later but I don't see the data in your first post, perhaps you mentioned it on another?
Many AGM's are constant voltage charge only - almost identically to gel batteries with fixed temperature adjusted float only.
There is a special AGM pendant available - it lowers the set points .4 or .5 volts but even that can spell overcharging with gas production that gets vented so you loose water and shorten battery life. The Intellipower non-pendant output level (on paper) is perfect for the AGM batteries I have chosen...
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
05-06-2007, 07:35 PM
Detroit Area
, Michigan
Um, it is a lifeline battery. So you're telling me the convertor I have won't work with it? That would really stink.
05-06-2007, 07:58 PM
Naples
Take a look at this: Lifeline Marine Batteries - AGM Marine Battery & AGM RV Battery
It will explain how Lifelines like to be charged.
lewster
05-06-2007, 08:05 PM
Naples
AFAIK, ANY battery will benefit from 3 stage charging. The above referral shows HOW to use 2-stage or single voltage charging, but they maintain the charge better at the float voltage.
The old Univolts used to charge at a single voltage, but they would cook a bettery if left connected after completing the charge cycle.
Gel batteries are much more voltage sensitive, as overcharging will cause the gel to separate from the plates leaving a 'scar' that greatly reduces the capacity. If you check the charging graphs on any modern 3 stage charger that allows you to 'set' the battery type, you will find that gels are at the lowest charge voltages, followed by liquid cells, with AGMs at the highest voltages.
PS: there is no 'water' in an AGM. The electrolyte is 99% absorbed in a glass mat and does not appear anywhere in the battery as a free liquid. This allows AGMs to be air shipped.......the only battery that can.
lewster
05-06-2007, 08:06 PM
Detroit Area
, Michigan
Which going from memory here, I think is about what the Intellipower puts out.
05-06-2007, 11:11 PM
1984 31' Airstream310
Dunsmuir
Isn't there a specific charge wizard available for AGM batteries. Randy would Know.
I was mistaken, the special charge wizard is for gel batteries. The same wizard is used for flooded cell and AGM batteries.
Charge Wizard (Gel)
1984 310 Limited Motorhome
05-07-2007, 05:33 AM
Detroit Area
, Michigan
That's what I thought.
05-07-2007, 05:39 AM
Naples
Looks like you got the wrong one:
Note: This Charge Wizard is specially calibrated for Gel type batteries. If you have regular flooded deep cycle or AGM batteries, please select the standard Charge Wizard. The Gel calibrated Charge Wizard incorporates slight lower charging voltages.
lewster
05-07-2007, 06:41 AM
Detroit Area
, Michigan
I do not have the Gel calibrated wizard. I have the regular one.
05-07-2007, 08:13 AM
Detroit Area
, Michigan
Ok so I think I have a correct convertor for this battery. I know this lifeline battery is in good shape (the worst abuse for reasons unknown happened this weekend when it was brought down to 11.9 volts). I still have a question about this charge wizard pendant thing. I know how to cycle it through modes manually but how do you take it out of the manual mode and make sure it is in auto mode?
05-07-2007, 08:26 AM
New Borockton
, Alabama
The standard CW profile is fine with Lifeline and other AGMs. The Gel calibrated CW is set .4 volts less in all modes.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
05-07-2007, 09:00 AM
Keep pushing the button until you get to normal (fast flashing) mode. Whatever mode it is in, it will return to normal mode after 4 hrs anyway. It will go to storage mode if the 12V system is idle for 30 hrs.
Also, if you mount the pendant where it is visible from a window, it will look like an alarm system. Especially if you also put an ADT sticker in the window.
05-09-2007, 09:12 PM
Detroit Area
, Michigan
Well thanks for all the advise. I'll see if it doesn't do better over Memorial Day. After a brand new Lifeline AGM and new convertor I expected better. I need to find out what drained the battery so dramatically, and run my generator until that battery is all the way topped off to 12.8+ volts and see if we don't do better this time.
