Old 05-07-2007, 08:26 AM   #15
New Borockton , Alabama
Images: 21
The standard CW profile is fine with Lifeline and other AGMs. The Gel calibrated CW is set .4 volts less in all modes.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 05-07-2007, 09:00 AM   #16
Images: 59
Originally Posted by wacnstac
. I know how to cycle it through modes manually but how do you take it out of the manual mode and make sure it is in auto mode?
Keep pushing the button until you get to normal (fast flashing) mode. Whatever mode it is in, it will return to normal mode after 4 hrs anyway. It will go to storage mode if the 12V system is idle for 30 hrs.
Also, if you mount the pendant where it is visible from a window, it will look like an alarm system. Especially if you also put an ADT sticker in the window.
Old 05-09-2007, 09:12 PM   #17
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Well thanks for all the advise. I'll see if it doesn't do better over Memorial Day. After a brand new Lifeline AGM and new convertor I expected better. I need to find out what drained the battery so dramatically, and run my generator until that battery is all the way topped off to 12.8+ volts and see if we don't do better this time.
wacnstac is offline   Reply With Quote
