Old 08-08-2016, 11:50 AM   #1
2016 23' Flying Cloud
Corpus Christi , Texas
New owner question about batteries
Converter went out and replaced. Question - are we suppose to charge the batteries via shore power when not using the AS about every three or four weeks. Also when charging the battery with shore power - refrigerator fan does not shut off. Have 2016 Flying Cloud.
2fromtexas is offline   Reply With Quote
Old 08-09-2016, 12:57 AM   #2
2015 30' Classic
Pleasanton , California
The short answer is yes, your battery is slowly being drained by the LPG detector. The current consumption is typically 75 to 100 mA from this alone. So charging the batteries up every 3 to 4 weeks sounds like a good plan. However, did you replace your converter with a three-stage battery charger? If not, then you'll need to make sure you don't leave the charger on for extended periods - otherwise you could damage the batteries.
Ideally, you should have a battery monitor to tell you the available battery capacity at any time. Only having the battery voltage alone is a poor surrogate to determine the state of the battery.
To avoid charging your batteries every 3 to 4 weeks you could also disconnect your batteries to avoid the drain from the LPG detector. This would probably allow you to go 3-4 months between charge cycles. You could add a simple disconnect switch rather than disconnecting the cables each time if you find this inconvenient. Another thing you could do is add a solar charger to keep your battery fully charged. Lots of options.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 08-10-2016, 02:14 PM   #3
New owner battery question
Much thanks for your reply and knowledge.
Old 08-10-2016, 02:27 PM   #4
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
2fromtexas. here is a recent thread on this subject that will provide some insight.
http://www.airforums.com/forums/f37/...ml#post1833442
note my post #19 refers to yet another thread that I have saved and often refer to.
LP detector, radios and in some instances the sub-woofer seem to be the culprits.
I disconnect my neg connection as I have no SP at storage. When it is hot and I'm not going to use in within 30 days I bring them home for a trickle and where I keep an eye on the water level.
CruizinDux is offline   Reply With Quote
Old 08-10-2016, 03:21 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
What ever else you do check that convertor and if it is not a 3 stage replace it with one. Airstream does not normally install a good unit.
Solar is a great option for maintaining the batteries while the trailer is sitting.
2004 Excursion 4x4
Old 08-10-2016, 03:47 PM   #6
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
When in storage I simply disconnect the negative battery post, this way there is no battery drainage & it stays charged for months.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 08-10-2016, 04:08 PM   #7
Long Island , New York
The OP says he replaced the converter.
Old 08-10-2016, 04:32 PM   #8
HowieE's Avatar
Images: 12
With WHAT?
2004 Excursion 4x4
Old 08-10-2016, 05:14 PM   #9
When you replaced the converter, did you upgrade to a better unit?
Peter
PS -- thanks HowieE, guess I made an incorrect assumption.
Old 08-11-2016, 10:08 AM   #10
New owner battery replaced and converter
Sorry to say it was under warranty and AS only gives back the same converter for replacement. Really appreciate all the responses. Learning a lot about what we need to replace and how to maintain our little beast.
Old 08-11-2016, 10:25 AM   #11
Thanks for the clarification.
Our OEM converters/chargers, in spite of their bad reps here, are quite serviceable if one knows their limitations. Given proper use and management, it will last years and years, as will the batteries.
In my personal opinion, the Parallax units are intended to be used actively in a trailer that goes on the road again. over and over. They do not do well at all in a "set it and forget it" mode. Lesson learned.
We intend to upgrade to a Progressive unit eventually. In the meantime, the old maxim applies -- if it ain't broke, don't fix it.
Our next upgrade cycle will hopefully include solar, the new converter, batteries, better cell reception, and so forth, and the nearest available quality shop is many miles and days of travel time away.
Happy Trails!
Peter
Old 08-11-2016, 02:12 PM   #12
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
When my AS is in storage mode, I just connect a Noma block heater timer to the power cord , and set if for 1 hour a day 'on'.
"LOOK AFTER YOUR EQUIPMENT,IT WILL LOOK AFTER YOU."
"Never eat more than you can lift"! (Miss Piggy)
MelGoddard is offline   Reply With Quote
Old 08-11-2016, 02:17 PM   #13
2007 22' International CCD
"If it isn't broken, break it, then fix it RIGHT!"--Old continuous improvement maxim.
(From an old engineer (me) that is very good at thinking outside the box and making things better)
I've never been content with merely letting well enough alone.😀😀😀
KE4GNK/AE
Old 08-11-2016, 02:31 PM   #14
Volunteering to come pick up our FC20, take it to a good shop, pay for the improvements, loan me your trailer in the meantime?
"Broke" is a relative concept . . .
Where to move batteries inside 23d. Upgrading to AGM batteries. Eyeballs Electrical - Systems, Generators, Batteries & Solar 29 01-08-2016 10:54 AM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 08:18 AM
Hi, new 63 overlander land yacht owner , are there two batteries on this thing? Nova3781 Batteries, Univolts, Converters & Inverters 6 12-29-2010 04:18 PM
NEW OWNER of One Owner 1972 Ambassador 29 foot Mrwaterway Member Introductions 11 11-20-2009 01:53 PM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 10:05 PM
