Old 04-22-2007, 06:24 PM   #1
lewster's Avatar
Naples, FL , Hood River, OR
New Lifeline 6 Volt Batteries
I just received a notice from lifeline (I'm a dealer) that seems to be saying that the 'old' GPL-4C 6VDC golf cart battery has been replaced by two new golf cart batteries.
The new GPL-4CT seems to have the same specs as the 'old' GPL-4C, but it seems that the dimensions are different: the height is LOWER and closer to a normal group 24 battery. The height of the new one is 9.62", where the old one was over 10", generally making it hard to fit into a group 24 battery box. the new GPL-4CT should take care of this problem.
For all of you power hungry folks out there.....the new GPL-6CT is much taller....13"..... with the other dimensions the same. It weighs 82 lbs each compared to the 66 lbs of the GPL-4CT, and it has WAY more minutes of discharge compared to ANY other Lifeline. The reigning champ at the 25 amp discharge level used to be the GPL-4C with 220 amp/hours rated capacity and 492 minutes of discharge at 25 amps.
The new GPL-6CT has 300 amp hours of rated capacity at the 20 hour rating and a whopping 690 minutes of discharge at 25 amps. I can't wait to see what they cost .
12 volt
Batteries & Solar Charles Q Treichel Generators & Solar Power 2 12-02-2008 12:06 PM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
Upgrading batteries Les Gilliam Electrical - Systems, Generators, Batteries & Solar 5 10-16-2002 11:58 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
