Old 07-03-2015, 04:42 PM   #29
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
What would be the recommended thickness and width? I understand that the bigger the better but what would be the "standard" for the ms 2012 model and 4 6v batteries worth at 190 AH a piece?
ArtisanAir is offline   Reply With Quote
Old 07-03-2015, 09:02 PM   #30
lewster's Avatar
Naples, FL , Hood River, OR
For 300 amp/hours or less, I use 1/8 X 3/4". For larger battery banks, 1/8 X 1".
Old 07-12-2015, 05:49 PM   #31
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Just thought to add more info on the inverter discussion. I did find that not all Asian brands are the same (obviously) most everything is built overseas but some carry the CE, UL458 and other ratings which provides more detail on the quality. One brand rated highly that is Chinese is GoPower. Four of their pure sine units are UL rated.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-12-2015, 06:02 PM   #32
lewster's Avatar
...........and unfortunately just like all of the other Chinese inverters, they are throw-aways when they fail!
Old 05-15-2018, 08:53 AM   #33
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Old thread but I'm in the market for either a 2000w inverter or 2000w inverter/charger.
Anyone have further thoughts given 3 additional years?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 05-15-2018, 08:57 AM   #34
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Very happy so far with our Victron hybrid inverter / charger, installed just over a month ago. Our model is 3,000 watts, though.
Rocinante is our 2014 International Signature 27FB
Old 05-15-2018, 09:08 AM   #35
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
3,000w could work. I'm wired for it. And I love Victron stuff. Have their solar controller and battery monitor which both work splendidly.
Do you know if they have a straight inverter that's 2000w or more? I only see 1200w and the inverter/charger gets spendy.
[edit] I do see one for about $1300. Still spendy.
Old 05-15-2018, 10:15 AM   #36
Rivet Slave
Rocinante's Avatar
Yup, Victron = Spendy returns TRUE.
Old 05-15-2018, 10:34 AM   #37
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
I hear ya. And went that way before. But I won't use the inverter a lot so was hoping to minimize cost here.
Old 05-15-2018, 12:26 PM   #38
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
Scott,
Here is a link to a users discussion of pros/cons of magnum vs victron:
http://www.rvnetwork.com/topic/12687...um-vs-victron/
They are very close when compared. I like durable on the trailer so I went magnum. Found many good prices but most low priced vendors were not authorized sellers by magnum.
TheCabin is offline   Reply With Quote
Old 05-16-2018, 04:06 AM   #39
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Originally Posted by TheCabin View Post
Scott,
Good to hear from you old bud!
Thanks for the link. If I was running my trailer with this i'd go victron but I'm really looking for something that will run a blender a few times a week without frying my rig.
Old 05-16-2018, 09:00 AM   #40
switz's Avatar
2014 31' Classic
2015 23' International
Apache Junction , Arizona
Images: 8
We used the Magnum MS-2812 on the Classic in 2014 as its had two 30 amp contacts which was what few needed with 50 amp two pole service. We put in a new primary power panel and redistributed the load so that one A/C, the refrigerator and water heater AC power loads where shed when on the 600 amp-hour lithium battery.
We put the Magnum hybrid MSH-3012 in our 23D with 30 amp service. It will pull power from the 300 amp-hour lithium battery to help start the single A/C when using just one propane powered Honda 2,000 watt generator.
ETO brand inverter generator nm1oqrz Generators & Solar Power 9 01-07-2011 06:26 AM
2010 Airstream Flying Cloud BRAND NEW!!!!! S2010 Airstream Flying Cloud BRAND NEW!! eBay Watch Airstreams on eBay 0 11-03-2010 03:50 PM
Inverter brand and switch LI Pets Batteries, Univolts, Converters & Inverters 7 09-29-2009 11:57 AM
Brand new Airstream owners! WolfSong Our Community 10 07-24-2003 08:22 PM
Brand new to this; need logistics advice 4521red Our Community 21 01-01-2003 09:07 AM
