04-18-2017, 09:03 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
New House Batts
Ok soooooooo..... long story short
I burned up one of my factory original group 24 interstate battery's this passed weekend with the stock single stage charger. Water level was fine, just shorted out a cell. The battery's were new Jan 2014
So just today ordered a new progressive dynamic pd4655v with remote and picked up two new Trojan T105 6 volt battery's. Did not go AGM due to cost (3 times as much and we do not have solar and do not boondock much. These two 6 volt Battery's will increase my amp hrs greatly over the stock system. I will have the raise the battery box lid 2" to accommodate the taller Trogans but, I can weld up an extender ring and bolt in place ( problem solved).
Thoughts?
Suggestions?
04-18-2017, 09:10 PM
Overkill Specialist
Dadeville
, Alabama
I will post pics of them mounted in place.
Does anyone else use these Trojan T105 flooded 6 volt batteries?
04-18-2017, 11:12 PM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Many folks have done the same, and they seem happy. Good luck, and post some photos! [emoji106]
04-19-2017, 08:56 PM
Overkill Specialist
Dadeville
, Alabama
Thanks. Picked up metal today to weld up extender ring for battery box. Going the increase batt box height by 2" to cover taller Trojan batteries
04-20-2017, 08:16 PM
Overkill Specialist
Dadeville
, Alabama
Battery box extension
Here are a few pics of my progress
04-20-2017, 09:32 PM
Green Cove Springs
Oh yeah, that is looking very promising indeed. Keep up the great work!
04-20-2017, 10:01 PM
2017 23' Flying Cloud
Parker
Nice work...
Troutboy
04-21-2017, 07:13 PM
Overkill Specialist
Dadeville
, Alabama
Final fit and primed
All holes drilled. Fit and Finnish up to par. Primed with self etching primer. Going to mount and paint entire trailer tonge tomorrow while I got it all apart
04-21-2017, 07:23 PM
Overkill Specialist
Dadeville
, Alabama
Here's a better look
Rough coat of paint
04-21-2017, 07:24 PM
Overkill Specialist
Dadeville
, Alabama
Paint I'm using. It matches the factor dark gray very well
04-22-2017, 10:08 AM
Overkill Specialist
Dadeville
, Alabama
Ring mounted
New longer thread all rod added and ring mounted
04-22-2017, 10:10 AM
Overkill Specialist
Dadeville
, Alabama
Fresh coat of paint
Painted all with a fresh new coat of paint while I had it all apart
04-22-2017, 12:29 PM
Green Cove Springs
Looks great! Here's wishing you lots of happiness with your new pair of 6V batteries.
04-22-2017, 03:52 PM
Overkill Specialist
Dadeville
, Alabama
Compare interstate grp24 to Trogan t105 6volt
Had to modify the stock battery tray to get Trogans to fit width ways. Length was perfect
04-23-2017, 06:00 PM
Overkill Specialist
Dadeville
, Alabama
Batteries in there new home! Progressive Dynamic 4655 going in tomorrow.
04-23-2017, 07:06 PM
2016 19' Flying Cloud
Portland
, Oregon
Looks amazing, great job.
It's hard to see from the photos but did you put any hose over the threads of the battery threaded rod?
The batteries look tight up against it so you may find the rod starts wearing on the batteries.
Otherwise, great mod
04-23-2017, 07:26 PM
Overkill Specialist
Dadeville
, Alabama
No hose. But good idea. Batts are in stock Battery tray so there is a spacer between them
04-23-2017, 07:29 PM
Overkill Specialist
Dadeville
, Alabama
Note tray
04-23-2017, 11:17 PM
Portland
, Oregon
Perfect. Looks like you planned for everything.
04-23-2017, 11:38 PM
2017 27' Flying Cloud
Beavercreek
, Oregon
You've got some skills there, nice work!
