Old 04-24-2017, 06:33 AM   #21
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I'm going to add a tube over the thread rod between the batterys as suggested by Snowy
Old 04-24-2017, 08:18 AM   #22
2007 31' Classic
Gulf Breeze , Florida
Nice work. I bought an extender from Vinnies that looks similar to yours. The T105 is a great battery and I have used them for years with good success.
trumpetguy is offline   Reply With Quote
Old 04-24-2017, 11:37 AM   #23
2016 19' Flying Cloud
Portland , Oregon
I should mention that if you put a rubber tube over the threaded rod that you might need to then also make a larger "washer"
In the photo above you can see a thick black plastic rectangle washer under the stock threaded nut.
As the rubber hose moves the batteries apart a little more I found the stock nut washer to slide off one of the batteries. The solution was the larger rectangle washer. Batteries are very secure now.
Snowy is offline   Reply With Quote
Old 04-24-2017, 02:04 PM   #24
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I used a piece on 1/2 pex pipe over the rod. Snowy, Where did you get your battery disconnect. Also love all the copper jumper plates. Looks awesome!
Old 04-24-2017, 04:08 PM   #25
Portland , Oregon
That's not really a battery disconnect, it's a big resettable fuse found on Amazon. Of course as it's between the two 6v batteries it has that function.
From experience if you plan to be disconnecting the batteries a lot then these resettable fuses are not a good choice. After a while the mechanism fails to latch back which would be a problem.
Old 04-28-2017, 08:49 PM   #26
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Loving the new PD4655. Can't stop playing with the remote. Batteries are nice and comfy in there new home!
Old 04-28-2017, 11:15 PM   #27
2015 30' FB FC Bunk
Point Pleasant , New Jersey
looking for a battery recommendation
i would prefer not go thru expanding my battery box to accept the Trojans (have the same batteries in our golf cart they are great). Is there a particular battery for "non-boondockers" that fit the stock battery box? I have seen on new units they have a larger battery box already. Smart move, little too late for me.
thoreau2104 is offline   Reply With Quote
Old 05-02-2017, 10:36 AM   #28
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
I have a related question. My 4 year old Class 27 AGM batteries failed and I replaced them in kind - different brand.
I am only getting 12.9 volts when connected to shore power. I have a 2013 Classic with the solar option.
I would have thought I would be getting 13.6 volts.
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 07-12-2018, 06:57 AM   #29
Herndon , Virginia
Thanks to all, good ideas Iwould not have thought of. 66coupe
66coupe is offline   Reply With Quote
Old 07-14-2018, 09:31 PM   #30
New Borockton , Alabama
Images: 21
He did a great job. First I saw this one. Nice work.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 07-14-2018, 09:35 PM   #31
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Thanks Randy for the vote of confidence.
Old 07-17-2018, 04:06 PM   #32
Wolfwhistle
Wolfwhistle's Avatar
Margaritaville , Banana Republic
Hey GMFL. Nice work and great post. Please tell me about the metal you used... what gauge? did you brake it yourself or have it bent?
Also do you think there will be enough ventilation with this design. Especially considering going to a more robust charger? That nearly meets the battery manufacturer's recommendations.
This factory converter has to go... I almost fell over when I read that it has a single stage charger.
WW
Wolfwhistle is offline   Reply With Quote
Old 07-20-2018, 04:25 PM   #33
JFTKSU78
jftompkins's Avatar
2017 23' Flying Cloud
Olathe , Kansas
ID:	317579 In our case: The before and after picture from Interstate Group 24 12V to Lifeline AGM 4CT 6V in series; did need to remove the automotive connectors and crimp ring terminals on (hydraulically)...replacement after doing the PD4655VL converter replacement..went well.. Battery box (no modification) is on our 2017 AS FC23FB....+40% capacity, sealed, hold charge better, and easy to pull in winter for storage.....the Group 27 AGM Trojans did not fit ..
jftompkins is offline   Reply With Quote
Old 07-20-2018, 07:49 PM   #34
Wolfwhistle
GMFL, forgive me if you answer this later in the post, but where did you put the remote? TIA
WW
Ford and 23 FB IS
Did changing to two 6 volt Batts. affect ride grizbear Towing, Tow Vehicles & Hitches 5 02-26-2015 12:24 PM
Can I leave my Interstate marine flooded batts on trickle charger in winter? bonginator Batteries, Univolts, Converters & Inverters 20 10-06-2012 12:06 PM
Is TV batt isolated from AS house batts? Gringo Tow Vehicles 16 05-30-2011 10:00 PM
How do batts re-charge? frozen chosen Electrical - Systems, Generators, Batteries & Solar 8 10-27-2003 04:59 PM
