Old 06-25-2014, 07:49 AM   #1
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
New converter for a '15 Classic with AGMs?
I've ordered a '15 Classic and was wondering if someone will recommend if I should swap out the converter?
I'll be installing (4) AGM Lifeline batteries and was thinking of installing a Progressive Dynamics 4655 converter/charger.
Do you think it's a good idea or is the standard converter/charger good enough?
Thanks in advance,
Ron
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
Rawn77 is offline   Reply With Quote
Old 06-25-2014, 01:31 PM   #2
dznf0g's Avatar
Oswego , Illinois
I'm not positive what AS is putting in for 15. I had heard they have gone to a 3 stage converter. I guess you need to know what it is being built with before I could say if it is good for AGMs.
-Rich-
Old 07-14-2014, 03:46 AM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I would suggest looking at the Magnum MS series if you are installing big batteries.
We installed four Lifeline 6CT 6Vdc 300 amp hour batteries (about 92 pounds each) in a custom stainless steel box behind the propane tanks along with eight 100 watt AM Solar panels and use a Magnum MS2812 to generate 2800 watts of pure sine wave power as well as charging the batteries based upon the battery temperature, air temp etc.
Wire size is important when looking at the 400 amp fuse going to the Magnum from the batteries.
PM me for more information and access to photos.
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Moving to Lifeline AGMs - but tongue weight is an issue Nightwatch Boondocking 5 04-01-2012 10:46 AM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
Checking condition of dual AGMs wayneskid Batteries, Univolts, Converters & Inverters 5 04-06-2010 01:58 PM
