Old 05-15-2015, 01:07 PM   #1
1977 31' Sovereign
Indianapolis , Indiana
New Converter
Name:	ImageUploadedByAirstream Forums1431712961.079372.jpg
ID:	238471Click image for larger version
Name:	ImageUploadedByAirstream Forums1431712979.834009.jpg
I'm upgrading to a PowerMax Boondocker. 3 wires run from the original converter. One is positive (see photo), one is negative (see photo), but what is the small white wire (see photo)?
Where do I ground the new converter?
Thanks!
jasonsherman is offline   Reply With Quote
Old 05-15-2015, 01:28 PM   #2
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Yours looks way older than mine, but when I upgraded to the PowerMax Boondocker, there where also 3 wires. White, Black and Copper solid wire. Pos & Neg I believe are tied straight into the battery and the Copper wire is a ground to the chassis.
It may be similar on yours, but without the solid copper and different color coding.
Best guess I can offer.
Family of 4 living, working & exploring the USA in our Airstream.
OUR BLOG | FACEBOOK | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 05-15-2015, 01:31 PM   #3
1977 31' Sovereign
The small white wire goes from the converter to the fuse panel. I don't think it's the ground, but not sure.
Old 05-15-2015, 03:30 PM   #4
1977 31' Sovereign
Is the white wire used by the control panel to show when the shoreline is connected? If so, I don't need it.
What's the best way to run a ground to the new converter?
Thanks ...jason
Old 07-06-2015, 03:00 PM   #5
1990 33' Land Yacht
Chance , Maryland
have a 1990 airstream landyacht with energenius eg3000 series the breaker with the white test button has blown, what do i do, and where do i get a new one?
bjkayla is offline   Reply With Quote
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 03:39 PM
New Power Converter 66 Tradewind Batteries, Univolts, Converters & Inverters 10 07-06-2015 03:04 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 03:59 PM
New converter and batteries flsafari Electrical - Systems, Generators, Batteries & Solar 19 04-30-2006 05:04 PM
Batteries Short...New Converter robandzoe Electrical - Systems, Generators, Batteries & Solar 25 03-22-2005 12:38 PM
