Old 10-08-2008, 12:10 AM   #15
Jjfester's Avatar
1975 27' Overlander
Schenectady , New York
Thank you all for the suggestions. Once I have a day off to test them out, i'll repost to let you know how it goes.
Jjfester is offline   Reply With Quote
Old 10-08-2008, 04:42 AM   #16
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Sounds like a bad connection. I would be highly suspect of the little meter on the airstream! My meter did the same thing when all lights worked good,so I would not place much stock in what it is telling you. Except the meter does show that a circuit exists. Check the cable ends where they attach to the battery. if they are the kind where the lead end bolts to the cable disassemble them and clean with a wire brush.
Diesel1 is offline   Reply With Quote
battery, no power
The Battery ChrisAich 2002 - 2005 International 14 10-18-2008 11:30 AM
To battery or not to battery 29348 Batteries, Univolts, Converters & Inverters 4 07-16-2006 02:02 PM
Which Battery Craftsman Batteries, Univolts, Converters & Inverters 4 07-30-2004 10:01 AM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
