Old 11-27-2010, 02:10 PM   #1
tradewindtom's Avatar
1974 25' Tradewind
Magnolia , Texas
New battery, no power?
Hello all. Just got my first trailer, '74 Tradewind, and put a new battery in it. None of the lights come on. When I have it plugged into a 110V, everything works. I should have lights and everything working on only battery power, correct? Any advice would be most helpful to a novice. Thanks.
tradewindtom is offline   Reply With Quote
Old 11-27-2010, 05:03 PM   #2
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
On my 1967 Tradewind I have 2, 30amp 12v. automotive type fuses in the cables that come of the battery. Check those, also right after the fuses you may have 3 automotive type 12v. 20-30 amp relays, those also could be bad. Adios, John
Diesel1 is offline   Reply With Quote
Old 11-27-2010, 08:12 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
If I remember correctly trailers of that era had a connector in the battery cable that could be unplugged. You might want to check that, both to be sure that it's plugged in, and that it's still connecting reliably.
Old 11-27-2010, 08:29 PM   #4
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
The Univolt charger is a big blue box with the fuses in it for the 12volt system. In my 72 it was in the closet in the bathroom under a panel. It will be fairly close to the battery. Most people put in a new 12 volt contertir (intellipower) but keep the fuse panel.
RichHog is offline   Reply With Quote
Old 11-27-2010, 09:01 PM   #5
Ottawa , ON
On our '74 (which has the rear bath) there is an inline fuse connected to the blue Univolt, and it goes to the battery. If yours has one of those, have a look.
Um, this might sound silly, but do you know for a fact that the battery is charged? A five-dollar voltmeter is a handy thing to have on a trailer...
Oh, and welcome to airforums!
ps: how about some photos of your new baby?
Old 11-28-2010, 06:12 AM   #6
1995 34' Limited
Sarasota , Florida
I have a 98, 31' excella. while changing out the electric jack at the tongue the hot with accidently touched the frame. now have no 12V power. have looked for reset button per manual in fuse box at front of unit behind sofa. can't locate red reset buttons.
any idea where else to look?
GatorDave is offline   Reply With Quote
Old 11-28-2010, 06:54 AM   #7
1974 25' Tradewind
Magnolia , Texas
Smile
Thanks for the info guys. Found the problem...the ground wire that attaches to the in line fuse (before the fuse panel) was loose. Tightened up the screw and voila. Lights all came on. Thanks so much!
Tom
Old 11-29-2010, 08:18 AM   #8
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Tom I found also that the fuse holders, being old can sometimes loose connection and a section of overhead lights will go off. Had that happen in the bathroom light and the third overhead light. Road vibration can cause a lot of things to come loose after travel and the fuses and associated cabling is a part of that.
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
No battery power wallybyam Batteries, Univolts, Converters & Inverters 6 01-25-2010 04:26 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
No Power from Battery John Sims Batteries, Univolts, Converters & Inverters 5 08-01-2006 12:02 PM
