Old 12-23-2013, 03:36 PM   #1
1976 25' Tradewind
grover beach , California
New Battery
I changed the battery in my Airstream this weekend. I put in two 6 volt deep cell golf cart batterys in seires to make 12 volts. I have 230 amps of power before I only had 120 amps. I put them in the space under my oven it was kind of snug but a good fit. I will try and post photo later.
larry smith is offline   Reply With Quote
Old 12-23-2013, 03:57 PM   #2
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Do the new ones have 230 amps in EACH 6 volt? Or are they 115 amp each? When you series connect 2-6 volt batteries your voltage will go to 12 volts but you are not doubling the amp hours.
Bikerbill is offline   Reply With Quote
Old 12-23-2013, 04:06 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Golf cart batteries have about 230 amp hours at a 20 hour rate at 6 V. So, two of them in series gives you about 230 amp hours at 12 V.
David
Old 12-23-2013, 04:30 PM   #4
richinny's Avatar
2011 34' Classic
batteries vent explosive gasses. under the oven? YIKES!
Ricky
Old 12-23-2013, 05:52 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Battery boxes vent to the exterior of the trailer, not to the interior. Assuming the OP installed them in a properly-designed battery box, of course.
For reference, the Lower Explosive Limit for hydrogen is 4% by volume in air. How much hydrogen would you have to vent from your house batteries to yield at least a 4% concentration in air?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-23-2013, 06:22 PM   #6
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Were they AGM batteries? No gas and longer life - I have a furnace under my oven.
Silver Hawk is offline   Reply With Quote
Old 12-23-2013, 07:11 PM   #7
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
battery under the oven.
a fan would help that out.. so now how would you do that in the space under a oven. where would it vent out. just thinking out loud.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 12-25-2013, 04:02 PM   #8
1976 25' Tradewind
I think I need a sealed box with a vent out the old battery box.
Old 12-25-2013, 04:40 PM   #9
1976 25' Tradewind
6 volt golf cart battery photo
battery photos
ID:	202321   Click image for larger version
Old 12-26-2013, 07:37 AM   #10
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
Report after 5 years 70,000 miles on 6V batteries.
In 2008 I installed Lifeline 6V batteries in my 25 Safari.
Thread is http://www.airforums.com/forums/f449...tml#post514373.
Reporting after 70,000 miles and 5 years, they still work!
No maintenance other than 2 years ago I cleaned the terminals. I also
had them load checked and they were good.
I have a voltmeter in my trailer and I see about 0.1 v per month decrease in cold
storage. So I can get four months of storage and lose only .4 volts, at which time
I either go somewhere or charge it up.
Performance has decreased a bit. But it is small, since I can't really measure it.
I maintain by monitoring voltage. When boondocking, about 1/2 discharged I recharge on the road or with a powered site.
This lasts about 2 days when 30 deg. outside, using shower and furnace. I have a couple of solar panels on top that supplements. But not much on shoulder seasons.
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 12-26-2013, 07:43 AM   #11
That's true, you might want to rethink your installation. Perhaps you can seal the battery area and vent it to the outside.
handn is offline   Reply With Quote
Old 01-13-2014, 05:19 PM   #12
1976 25' Tradewind
Well I took the trailer out for the first trip with the new batterys. They worked like a charm. We went to Kirk Creek camp ground in Big Sur for New years and stayed nine days. the baterys still had juice when i got home. My old 12 volt deep cell battery would only last 7 days max.
Old 01-14-2014, 03:42 PM   #13
carl2591's Avatar
2005 31' Classic
anyone putting a battery desulfator during usage and non usage to help with that problem. I read that is a big issues especially with deep cycle batteries.
I put one on my van battery and it did help after about 3 weeks.
Carl, Raleigh NC
