Old 04-25-2017, 08:24 AM   #1
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
New Batteries from Battle Born
I finally sprang for the new Lithium Ion Batteries from Battle Born in Reno, NV. These batteries are 100 ah each and weigh in at less than thirty pounds apiece. Also installed a new solar controller from Zamp with 60 ah capacity.
Name:	Lithium Ion Batteries.jpg
ID:	284120   Click image for larger version
Name:	Lithium Ion Batteries 3.jpg
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 04-25-2017, 08:37 AM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I'm hoping more lithium batteries will come out with a wet cell/AGM form factor with built in BMS
I don't need as much battery capacity as you do so two of these should fit in the same foot print of my two new Lifeline 6v. Two Battle Born 100ah lithiums would give me a useable 160ah vs 110 ah for the 6v AGM, stored under my street side twin bed.
Hopefully by the time I need to replace the Lifelines I can get two 100ah lithiums for $899. Right now the price is still too much for an additional 50amp useable capacity over my Lifeline 6v.
Hope the company stays in business. They are more affordable than the Relion 100ah lithiums
Thanks for sharing
Kelvin
Old 04-26-2017, 10:25 AM   #3
Photobum's Avatar
I spent a great deal of time with the owner and his chief engineer. They are smart and are doing well. They are also funding research for a new concept in batteries. They are American made which was a plus for me.
It was great fun to see how the batteries are made...I think I understand batteries much better now.
Old 05-19-2017, 09:18 AM   #4
Reno , Nevada
Vincent,
Thank you for coming by to see us. It was a pleasure to meet you. We look forward to hearing about your adventures.
Let us know if you need any more help.
Sean
battlebornli is offline   Reply With Quote
Old 04-13-2018, 04:43 AM   #5
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Does anyone have a state of charge (SOC) chart they use for the Battleborn Lithium battery?
Thanks!
Old 04-13-2018, 06:30 AM   #6
2013 25' International
Boise , Idaho
From Battle Born
Sean sent me this awhile back.
afk314 is offline   Reply With Quote
Old 04-13-2018, 07:40 AM   #7
Hans627's Avatar
Thanks for taking the time to send this to me.
Please excuse my ignorance, could you explain this chart a bit? I'm not sure why it shows a LOAD across the top.
Again, thanks!
Old 04-13-2018, 07:45 AM   #8
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Thanks! Confirms what I see with mine.
@living.somewhere.yonder | Instagram
SCOTTinNJ is online now   Reply With Quote
Old 04-13-2018, 08:23 AM   #9
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Again, thanks!
I don't know for sure, but I suspect the numbers across the top are the current load in Amps. So realistically for most nominal uses you will be looking at only a few entries, circled below in red.
Old 04-14-2018, 07:40 PM   #10
formerly Xipper
2011 22' Sport
Portland , Oregon
Voltage isnít overly precise, an actual battery monitor is the only way to get very accurate. However unlike lead acid you can guesstimate the SOC based on voltage with lid applied, if you know the load as it pulls the voltage down with more load.
As you can see, SOC100% with a 100amp load pulls the voltage down from 13.4-13.6 to 12.2V.
SilverHouseDreams is offline   Reply With Quote
Battle Born LiFePO4 batteries fran&frank Batteries, Univolts, Converters & Inverters 258 05-12-2018 12:23 PM
Hi everyone! New Adventurer Born Today! OhYesItsCree Member Introductions 9 03-07-2015 07:03 PM
Incredible "Battle of the Beasts" genearnold Off Topic Forum 4 08-09-2007 04:31 PM
Labor is over, New Airstream Born DreamStream 2005 and newer - Bambi all models 5 03-04-2005 11:38 AM
