Old 10-31-2015, 10:28 AM   #1
Richmond , Virginia
new batteries but no power
Hi,
new owner of a 2004 International and on a learning curve.
I have two new marine batteries I just hooked up from Advance. The jack/jack light work at full power. But nothing onboard is getting power. Everything is fine on shore power. Just no battery to all the non-jack systems onboard.
*The battery disconnect is lit red and the switch is set to 'use'.
*It doesn't appear any fuses have blown.
*Batteries are stickered new "9.15"
Anyone know what the cause, or what I should be troubleshooting?
thanks,
Barry
barryprivett is offline   Reply With Quote
Old 10-31-2015, 10:40 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
First, toggle the "store/use" switch to see if it is on or off. The light is a meaningless indicator it will be on all the time. If this does not fix the issue, then look at the small light on your propane fume detector which should be near the floor someplace inside the trailer. If the light is not on then I suspect the battery or the battery connection. Try using a voltmeter starting at the battery terminals and work your way outward towards the appliances/outlets to locate the failure.
Bob Martel
WBCCI# 5766
Old 11-02-2015, 06:14 PM   #3
Richmond , Virginia
thanks for the response. I ended up replacing the inverter fuses, even though to me they didn't 'look blown...but in fact were. Will be getting a multimeter...
Old 11-03-2015, 06:44 PM   #4
Chelsea , Michigan
Images: 12
Glad it worked out for you!
Bob Martel
WBCCI# 5766
Dual Batteries - But should I use only one? TankerIP Batteries, Univolts, Converters & Inverters 13 07-27-2015 08:27 AM
HELP?! On Shore Power, but lights dim, and power fades TGadaire Batteries, Univolts, Converters & Inverters 4 11-24-2012 05:18 PM
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
Batteries say charged but nothing works OKJerry Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 6 06-12-2011 07:03 AM
Want to move batteries.... but where to run the wires? barts Batteries, Univolts, Converters & Inverters 2 01-17-2010 09:03 AM
