Old 03-10-2015, 01:47 PM   #1
2012 30' International
Key Largo , Florida
New batteries
i am looking to replace the original SRM-24 Interstate batteries in my trailer. I have been a little neglectful with the checking/maintenance of these batteries and suspect that if I replace them with similar I will not change.....any suggestions for an install and forget alternative battery type that will not require any cutting or modification of the battery box on my 2012 International 30 and has at least similar capacity?
Martin R is offline   Reply With Quote
Old 03-10-2015, 01:51 PM   #2
dznf0g's Avatar
Oswego , Illinois
Martin, are your batts in doors on either side of the tongue, like a Classic? If so group 27s fit easily. Interstate group 29s (which I have) will fit without any modification, but barely and you have to be very careful while sliding them in and out.
ooops, never mind, I see you want to get away from Lead acid.
-Rich-
Old 03-10-2015, 02:12 PM   #3
Key Largo , Florida
New batteries
They are in a single box centred in the A frame behind the propane tanks. I have read elsewhere of others who have trimmed the lip of the battery box to enable 27's to fit (believe even up to 31's have been squeezed in) but I am happy to stick to 24's. Specifically, what is my best bet for similar (not necessarily better) from a maintenance free battery. I read a little about Optima AGM batteries but I think it may have been Lewster who cautioned that the Airstream electrical systems were not really compatible witness batteries without some upgrading and besides being expensive may not be as great as one would hope.......
Old 03-10-2015, 02:40 PM   #4
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Honestly, I'd stick with Lead Acid unless you are willing to upgrade the 1 stage converter. Otherwise throwing money down the drain. No point to AGM's for the cost with the single stage. Not to mention the extra cost + weight. And if you want to stick to that size, there is really no point in replacing your batteries with anything else. The whole reason to upgrade is more power/better discharge, maybe save weight with lithium batteries, but there is a cost investment with those.
Just my personal opinion on the matter.
Family of 4 living, working & exploring the USA in our Airstream.
OUR BLOG | FACEBOOK | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 03-10-2015, 02:48 PM   #5
Key Largo , Florida
I am not knowledgeable as to what alternatives to the lead/acid battery may exist as a simple switch over but your assessment is not really a surprise and probably right for us: stick with the type we have... (and pay more attention to them)..
Old 03-10-2015, 02:57 PM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The nice thing about AGM's is you never have to look at them to fill with water. The bad thing is that they cost more than standard batteries so when the piece of crap single stage charger that Airstream installed fries them, you feel worse.
Get a three stage charger and AGMs and then you'll be a happy camper!
Bob Martel
WBCCI# 5766
Old 03-10-2015, 05:55 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The problem is the converter/charger will ruin any battery since it can't step down the charging power, once the battery is fully charged. So you have a few choices. Replace the existing unit with a multi-staged converter/charger. Perform more frequent checks of the fluid level to keep the plates submerged. Don't keep your trailer plugged into shore power when it isn't being used. I chose the last option and have never boiled the batteries since.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-10-2015, 06:37 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
It's really a simple problem:
• keep the garbage constant voltage converter that your trailer comes with and use garbage, cheap batteries from Wal-Mart or other bargain outlet and just keep replacing them (lot's of folks seem happy with this solution and end up changing batteries every couple of years)
••••••••••••••OR••••••••••••
• replace that Parallax battery burner with a proper 'smart' converter/charger with 3 stage automatic charging (like a Progressive Dynamics unit made in the USA!) and upgrade to AGM batteries that will take NO MAINTENANCE and will likely last you 5-7 years if you don't deeply discharge them on a regular basis.
Lifeline group 27s will fit your battery box (group 31s will NOT FIT) IF you slice a small section out of the lip, and will give you a total of 200 amp/hours of reliable DC power. Optimas in the group 24 size (I don't think they make larger ones) are rated at 55 amp/hours each and you will be DECREASING the size of your present battery bank from 160 amp/hours to 110 amp/hours.
That's my take on your problem. It's your choice of maintenance vs. none and repeated replacements vs. none. Obviously, there are costs involved. Only YOU can decide which way to go and what the value of each option is TO YOU!
Have fun with your decision process.............
Old 03-10-2015, 06:50 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you want to keep the converter you have and the wet cell batteries. And still have shore power when stored. Disconnect the positive lead of the batteries. Tape it off. The converter will provide 12 volt power to the coach when on shore power. By disconnecting the battery lead they won't be overcharged during storage.
My coach has only one group 24 battery. It does have a Progressive Dynamics Converter. But I still remove the battery when in storage. I have full time shore power while in storage. I can run any or all devices. Both AC and DC.
Old 03-10-2015, 09:06 PM   #10
Nomadic , USA
Is the battery box the same size on the 30 as it is the 27? Because Trojan Batteries 31xhs fit with the same modification as the 27's for 260ahs
31XHS | Trojan Battery Company
Photographic proof
But you did say Lifeline, maybe they're bigger. Not to dispute you.
Old 03-11-2015, 07:49 AM   #11
lewster's Avatar
Yep, just big enough not to fit.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 03-11-2015, 08:07 AM   #12
Nomadic , USA
Correction, the 31XHS is listed as fitment group size 30 in the technical specifications on the Trojan website. So I have been calling this battery the wrong size incorrectly.
My 27's didn't fit without trimming the box either. At least the ones from Costco with handles, I suspect with out the handles they would of dropped in.
Old 03-11-2015, 07:25 PM   #13
grizbear's Avatar
2004 25' Safari
Crestview , Florida
batts.
Lew has it right. I went with the PD4655 unit and made a 1 7/8" thick top extension to the battery box simple drilled four holes in top lip and used bolts to hold it on then replaced the top about one hrs work. Using 2 6 volt wet batts very happy with this set up. I was using cheap auto zone batts and a portable 3 stage charger and got 4 1/2 yrs out of the last set after I learned how to maintain batteries which is the key to battery life. Best of luck Rand
grizbear is offline   Reply With Quote
Old 03-23-2015, 09:56 AM   #14
dstalzer's Avatar
2005 25' Classic
Lew,
Which Progressive Dynamics converter/charger is the correct one to replace my Parallax 7455 in my 2005 Airstream Classic?
Dennis
dstalzer is offline   Reply With Quote
1992 Airstream B 190 118,000 miles new tires, alternator, 2 new batteries. eBay Watch Airstreams on eBay 0 07-29-2013 08:50 AM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 08:18 AM
Batteries Short...New Converter robandzoe Electrical - Systems, Generators, Batteries & Solar 25 03-22-2005 12:38 PM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 10:05 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 11:01 PM
