Old 04-07-2011, 10:11 AM   #15
1986 25' Sovereign
Plant City , Florida
Originally Posted by Wsmith View Post
I would do it right and buy the full cord and re wire it into the junction box. I am a industrial electrician and deal with industrial 480v plugs for welding machines and large a/c portable units. We go into each plug before using it after a equipment move. You would be surprised the problems of a loose wire. I am talking about 200-300 dollar power connectors that are cast aluminum with pencil size stab posts.
I just replaced my total pigtail to my excella and it only took about ten minutes. I now have the molded head where the wires can't move around when you drop the head on the ground or into your bumper box.
1. its an outdoor connection
2. Its 220V
3. It can go phase to phase inside the aftermarket connector and blow out
4. The wiring can be stressed and pulled on if there is a stiff connection.
5. Then you can make a new extension cord with your old pigtail and use the after market connectors. It will not see much use but you have it if you need it. I would check these at least yearly.
This was my first thought but after searching these don't appear to be
readily available. Where did you get yours?
I know in molded plugs the spades are soldered to the wire. I thought
about doing this with an aftermarket plug after putting the screws to it. I
spoke to my father about this who is also very leary about the
aftermarket plugs. He used to work at the local state fairgrounds as the ME and he
said "You have no idea how many of these plugs melted and smoldering
because of a loose connection on the screws."
I guess my other option is to upgrade the trailer to a 50amp connection
and rebuild the panel inside. If I did this I would have to replace the panel,
rewire the inverter to only one leg of the panel and then I could run
everything at once with no problems.
ck21084 is offline   Reply With Quote
Old 04-07-2011, 11:20 AM   #16
richinny's Avatar
2011 34' Classic
Leviton makes two flavors of this 830-T plug. one is 'Household or Residential?' and the other is "Commercial". there is quite a price difference. home depot showed both on the webside but i didn't see it now.
830-T > Straight Blade Plugs (Commercial Grade) > Straight Blade Plugs > All Products from Leviton Electrical and Electronic Products
Ricky
Old 04-07-2011, 03:15 PM   #17
Wise Elder
Jammer's Avatar
2010 30' Classic
Looks like Midwest also makes a higher quality retrofit plug. Tweety's carries them.
Midwest 30 Amp Plug
Any RV place will have them. Here's a link for Tweety's:
Sigma Wire Power Cord - 25 Foot, 30 Amp
But don't count on the connectors being soldered or of high quality. Often they are just crimped.
You can also get just the pigtail and solder it onto your existing cord
Sigma Wire Molded Pigtail - 30 Amp, Male
Camping World and Adventure RV should also have them.
Old 04-08-2011, 07:50 AM   #18
1985 31' Excella
Fresno , Texas
I got mine here 30 amp Extension Cords from PPL for Sale Its on sale for 39.00. They are local for me but they ship all over. They were out of the OEM type so I just bought the extension cord and cut the end off.
Wsmith is offline   Reply With Quote
Old 04-08-2011, 07:59 AM   #19
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
2. Its 220V
I'm sure you really didn't mean that. It is not 220 volt.
Vaughan
Old 04-08-2011, 08:25 AM   #20
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by funkill View Post
I can't say that mine has seen much wear and tear but it appears much better quality than the ones I saw at Lowes. I also noticed several new A/S with a similar plug. When I inquired on this forum, I was pointed towards this plug. If you have access to more quality plugs - certainly *go for it*.
Below is the one that BROKE on installation - right at the point where you see the hex nut. That felt a lot cheaper initially too.
Laura
I put one of these on my power cord until the other end failed. I got too loose. Remember to ALWAYS use the locking ring.
Michelle TAC MT-0
Sarah, Snowball
Old 09-29-2016, 11:33 AM   #21
GypsyKarma's Avatar
1973 31' Sovereign
Atlanta , Georgia
ok, I was confused about this. I have a 1973 sovereign with a 30 amp cord and it runs 110 right?
GypsyKarma is offline   Reply With Quote
Old 09-29-2016, 11:42 AM   #22
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Correct unless somewhere in its history it was changed.
MICHAEL
30 amp, rv plug, replace
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 32 01-16-2018 11:40 AM
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 03:44 PM
Wet weekend in our Safari OR How I discovered the Blow Out Plug! Brow324 Plumbing - Systems & Fixtures 16 04-18-2011 11:15 AM
Question on using 50 amp sevice RLS Electrical - Systems, Generators, Batteries & Solar 16 02-04-2011 01:14 PM
Is it ok to plug in small oil/radiator heater? LawChick Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-10-2011 12:45 PM
