Old 06-24-2007, 01:30 PM   #15
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by overlander63
I remember a demonstration where a rusty nail was placed in a glass of Coke overnight. The nail was stripped of rust by morning...
I have also seen it eat thru a styrofoam coffee cup For neutralizing battery acid I use the baking soda and water or club soda if I happen to have any around.
Aaron
WBCCI #XXXX AIR #2495
Old 06-24-2007, 01:46 PM   #16
Images: 59
You should not use club soda or seltzer water for neutralizing battery acid. Club soda is carbonic acid; Coke, Pepsi, and all other carbonated beverages are phosphoric acid. Both are acidic and will not neutralize battery acid.
Club soda is very good for taking out wine or berry stains. The color in berries and wine is mostly anthrocyanins, which turn from purple at high pH to pink or colorless ar low pH.
Old 06-20-2015, 09:03 AM   #17
1989 25' Excella
Albemarle , North Carolina
I have a lot of acid (white powerlery) built up that has migrated to my frame and outside battery cover doors on the outside and hinge. Has alsoflaked black paint off and rusted frame. What mixture of soda and water would I use also could I mix it in a garden sprayer?
eldin is offline   Reply With Quote
Old 06-20-2015, 10:16 AM   #18
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Been using baking soda and coke for years on everything from boats, race cars and trailers. Works great. Follow up with a fresh water rinse to remove residue. It is not rocket science chemistry. No mixing required. Simply poor both on and watch the show.
MICHAEL
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
Battery Slide Out niftypkg Electrical - Systems, Generators, Batteries & Solar 5 01-01-2003 03:41 PM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
