Old 11-01-2008, 06:50 AM   #1
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
Neg. Batt. Fuse location?
Shouldnt there be a fuse betw. the neg. batt terminal and the connection pt in the old uni distribution panel?--say a 40 or 50 amp fuse?
I dont think my 71 safari has one.
Im trying to get her up and running with a new zantrex 60 [from randy] and am using the front half of the old univolt for the distribution panel---thanx--jim
I see #3 in the pic but its not on the panel?
jamesardis is offline   Reply With Quote
Old 11-01-2008, 06:54 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I don't see why the negative side would be fused.
Wayne&Sam is online now   Reply With Quote
Old 11-01-2008, 07:21 AM   #3
richinny's Avatar
2011 34' Classic
this might help:
http://www.airforums.com/forums/f37/...tml#post307197
Ricky
Old 11-01-2008, 09:33 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Unless it has been removed, it should be mounted on the interior skin, along the floor, close to the battery and Univolt. You should be able to find it by following the wires going from the Univolt to the battery.
Old 11-01-2008, 10:26 PM   #5
Silver Hilton
Mark Wiltrakis's Avatar
1959 24' Tradewind
Astoria , Oregon
Can I get some more fuse info: I'm starting on my 12v wiring in my Tradewind, and plan to use a Xantrex 60 converter. I picked up a fuse panel today (Parallax FB12). Their literature shows a fuse between the battery positive terminal and the converter's positive input ("within 18 inches of battery"), but none on the negative side of the battery. Is this an either/or situation in which having a fuse on either side of the battery will suffice, or are you folks suggesting fusing both sides of the circuit? Either solution would be easy. Finally, are appropriate fuses readily available at an auto parts store? Hoping to avoid shocks, smoke, and meltdowns -
Mark
Mark Wiltrakis is offline   Reply With Quote
Old 11-02-2008, 04:09 AM   #6
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
Ricky- thanx for the link-Im a believer in a fused ground now.
Terry-thanx- I never thought of looking on the inside wall for it-I'll take a look
Looks like both sides are fused and if I cant find a fuse [ for the neg side] on the interior skin-Im putting one in--
a 40 amp blade ok?
one more question--on the zantrex there are two posts, Im assuming for ground connections- do I just connect them to the interior skin?--Randy?
thankyou all !-----------jim
Checked the Batt fuse lately? thecatsandi Tow Vehicles 14 11-26-2007 09:45 AM
Interstate DVD fuse location rving42 Sprinter and B-van Forum 2 03-11-2007 09:32 AM
Fused Neg. at panel?? Phil Gobie Electrical - Systems, Generators, Batteries & Solar 3 02-19-2007 05:59 AM
Power w/o batt. just shore... crazylev On The Road... 8 11-12-2004 04:14 PM
12v fuse panel location? coldduc All Argosy Trailers 5 05-26-2004 06:15 PM
