Old 05-16-2010, 10:08 AM   #1
nkeeler's Avatar
1977 23' Safari
Prince George , British Columbia
need to replace my univolt, but with what???
hey everyone, i need to replace my univolt, but i am having a problem deciding with what? and what size?
the Intelapower seems to be popular, but what size should i get, we have a 77 23 ft Safari?
any suggestions would be good
thanks and have a great day
nkeeler is offline   Reply With Quote
Old 05-16-2010, 10:37 AM   #2
1975 29' Ambassador
Reno , Nevada
The IP with chargewizard is a good choice and I think the WFCO is another with a good battery maintenance mode.
For RV's, a converter that has intelligent, 2 or 3 stage charging plus a maintenance mode that will keep a full charge and use some technique to inhibit sulfation is a good way to keep batteries healthy and long lived.
As for size, most folks don't need much more than 40 amps or so. That will charge 2 batteries at a proper clip and take care of most common loads. But, if you spend a lot of time connected to grid power and use a lot of 12v accessories, you might want a converter with a bit more capability. Excess capability doesn't hurt.
bryanl is offline   Reply With Quote
Old 05-16-2010, 05:35 PM   #3
New Borockton , Alabama
Images: 21
Bryan is correct. Most people over size. For a 23 footer and one or two batteries a 45 amp unit is all you need. 25-31 footers I recommend 55 amps. I have been basing this for years on the general number of DC accesories in a typical RV and I'm usually on target but ocassionally a rock band will call and want to rehearse in their RV and then it gets a little complicated...Kidding aside, all you need is 8 AWG for 45 and preferably 6 AWG for 55 and I would personally buy as large a unit as the wiring to the battery will handle. Good luck.
888-828-1893
Bestconverter.com
68 Overlander is offline   Reply With Quote
Univolt Help Fairleigh Batteries, Univolts, Converters & Inverters 19 12-02-2008 12:17 PM
Where is my Univolt?? Joe1261 Electrical - Systems, Generators, Batteries & Solar 5 01-22-2007 08:39 AM
Atwood Converters to replace Univolt????? leefields Electrical - Systems, Generators, Batteries & Solar 2 05-08-2006 09:27 PM
Univolt bear4500 Electrical - Systems, Generators, Batteries & Solar 18 06-02-2005 02:51 PM
Trickle charger to replace Univolt jwaldin Electrical - Systems, Generators, Batteries & Solar 2 02-18-2003 10:12 AM
