Old 06-08-2014, 08:52 PM   #1
1972 27' Overlander
Denver , North Carolina
Need new Fuse block
Hey Folks, I have an Intellepower using the old 1972 fuse block. It's shot. There is one connection that has no fuse it was hardwired in, see picture attached. I need to replace it and am looking for options. Suggestions would be appreciated.
Thanks!
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 06-08-2014, 09:02 PM   #2
1963 19' Globetrotter
Moline , Illinois
I like Blue Sea brand , a very high quality marine product. West marine carries a lot of Blue Sea products and I see now that they are showing up in some of the RV catalogs.
63air is offline   Reply With Quote
Old 06-08-2014, 09:20 PM   #3
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
same opinion as 63air.
I have the 12 circuit.
It's well engineered and designed.
BLUE SEA SYSTEMS ST Blade Fuse Blocks | West Marine
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 06-08-2014, 10:01 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Those are well made units. I use them regularly. Most of what Blue Sea Systems makes is of high quality.
Progressive Dynamics also makes a very nice 12VDC distribution block with indicator lights to let you know which fuss is blown.
Old 07-17-2014, 11:30 AM   #5
AirConditioner's Avatar
Fuse block alternative
Thanks!
I just completed this on the road last week. I used a 6 circuit automotive block from Advanced Auto for $10.00 . Here's the full post:
http://www.airforums.com/forums/f449/bye-bye-univolt-hello-wfco-122059.html
AirConditioner is offline   Reply With Quote
Old 07-17-2014, 12:27 PM   #6
1974 Argosy 20
Kooskia , Idaho
I would guess that the hardwired circuit with no fuse (and wire nut) might have been the charge circuit from the tow vehicle. It should be fused too.
The blade fuse panels mentioned above are all good ones.
The metal block with wires on the upper left side of the photo (and in the negative side of the power system) is the shunt for the ammeter in the control panel. It could be re used, but might just as well be eliminated in your new fuse block configuration. It is kind of a pain to substitute for and those old analog control panel ammeters were not very useful anyway. A new digital one, or a Tri Metric battery monitor will give you much better information.
Old 07-17-2014, 12:53 PM   #7
1981 31' Excella II
New Market , Alabama
Don't they make DC circuit breakers that don't require the use of disposable fuses?
Perry
Old 07-18-2014, 11:03 AM   #8
1974 Argosy 20
Kooskia , Idaho
Perry
Yes but there are two problems.
Most of the simple ones are self reseting and if there is a dead short on the line, they will trip, reset, trip, reset and on and on which is a bad thing and dangerous in the long run.
The DC breakers which look like normal AC circuit breakers with a little switch handle are really expensive and hard to come by. In most cases they are overkill for the job.
A simple DC automotive type fuse is a good solution overall. It is inexpensive and easily replaced. Often they last the lifetime of the device or wiring protected. If you have circuits which are blowing fuses commonly, something else is wrong and should be repaired.
I like the new fuse panel provided with my replacement PD 4645 converter/charger. It has an LED for each fuse position. If the fuse blows, the LED lights up allowing you to easily find which one it is. Very clever.
Old 07-18-2014, 11:32 AM   #9
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I used a 12 circuit fuse block from the auto parts store,
I figure by the time it wears out there will be something new and better, the glass fuses lasted 35 years, not I have auto blade fuses.
Grote makes really good stuff. I get my stuff from a truck supply shop in town.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Broken Fuse Block In Distribution Panel - How Best To Repair montanaandy Batteries, Univolts, Converters & Inverters 12 06-01-2015 08:01 PM
Need a Fuse Block diagram for a 1990 345 Tommoran Mechanics Corner - Engines, Transmission & More... 2 06-03-2013 08:59 AM
new fuse block bilby05 Batteries, Univolts, Converters & Inverters 8 01-16-2008 05:47 PM
Fuse block driving me nuts! bkahler Mechanics Corner - Engines, Transmission & More... 11 07-08-2007 08:52 PM
Fuse Block replacement - help Craig Electrical - Systems, Generators, Batteries & Solar 6 10-13-2004 03:01 PM
