Old 02-27-2011, 10:52 AM   #1
1973 31' Sovereign
Montalba , Texas
Need help with control panel
I have changed out my converter and fuse panel. i have no power at control panel i have found a gray wire that is hot but do not know where it connects to in the control panel. no other electrical issues .can anyone help.
mkcox is offline   Reply With Quote
Old 02-27-2011, 10:58 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Is the control panel dead or is it just the power on indicator that is not working?
Richard
azflycaster is online now   Reply With Quote
Old 02-27-2011, 11:28 AM   #3
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
This may help, may not.
Attached is the control panel section from the 75 Service manual.
It shows the blue and white from the tv attached to the control panel and otherwise just the wiring harness. Or, I could have missed something.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 02-27-2011, 01:01 PM   #4
x
XXXX , XXXX
Control Panel Wiring
The grey wire should attach to the main harness connector just beside the larger white wire ans above the red wire. On the other side of the main harness connector the grey wire has a bullet connector attached to it and connects to a white wire for the power on light. I have attached a wiribg diagram for the control panel and some pictures of the main harness connector. I am holding the grey wire with one finger. The first pic shows the harness from the trailer, the second shows the harness for the control panel and the third shows the bullet connector and the power on light.
Name:	2-27-2011 1;53;33 PM.jpg
ID:	123207   Click image for larger version
Name:	Control Panel Wiring 003.jpg
Name:	Control Panel Wiring 004.jpg
ID:	123209   Click image for larger version
Name:	Control Panel Wiring 005.jpg
wasagachris is offline   Reply With Quote
Old 02-27-2011, 01:45 PM   #5
1973 31' Sovereign
Montalba , Texas
control panel and indicator not working
Old 02-27-2011, 02:10 PM   #6
1973 31' Sovereign
Montalba , Texas
i have connected the gray wire the way it shows and connected black wire to ground the way andy suggested in early post. the light come on but when electric power is disconnected the stays on. and i have on power at panel ie radio and no other functions at panel
Old 02-27-2011, 02:35 PM   #7
2002 25' Safari
Dewey , Arizona
Images: 62
The original univolt had a separate line that powered the power on light. It was isolated from the battery and only operated from the 12 volt line from the univolt. With another converter the light will not function correctly.
My control panel (75) has a separate fuse located at the panel. I am not sure if it was the same in 73.
Richard
Old 02-27-2011, 02:52 PM   #8
1973 31' Sovereign
Montalba , Texas
yes i have a fuse in the panel and it is good
Old 02-27-2011, 02:53 PM   #9
2002 25' Safari
Dewey , Arizona
Images: 62
Do you have 12 volts at the fuse?
Richard
Old 02-27-2011, 03:09 PM   #10
1973 31' Sovereign
Montalba , Texas
no 12 volts at fuse
Old 02-27-2011, 03:27 PM   #11
2002 25' Safari
Dewey , Arizona
Images: 62
On my 75 TW the power to the CP is on circuit number 5. I would go back to the new fuse panel and verify that each circuit is connected and that the fuses are all still good.
Also see if any other 12 volt items are not working. Check all the lights and motor including the jack and water pump. I suspect that the entire circuit is dead.
Richard
Old 02-27-2011, 03:35 PM   #12
1973 31' Sovereign
Montalba , Texas
yes i have 12 volts at panel now
Old 02-27-2011, 03:36 PM   #13
2002 25' Safari
Dewey , Arizona
Images: 62
What changed?
Richard
Old 02-27-2011, 03:42 PM   #14
1973 31' Sovereign
Montalba , Texas
i connected the wire from car battery and i have power to the jack and to panel but the water pump and holding tanks will not light up
Old 02-27-2011, 03:48 PM   #15
2002 25' Safari
Dewey , Arizona
Images: 62
That circuit gets it power at one end from the fuse panel, but also feeds power to the battery from your TV. Since this all started with replacing the fuse panel, I would focus in on that area first.
Richard
Old 02-27-2011, 03:55 PM   #16
x
XXXX , XXXX
The 73 service manual shows a seperate red wire powering the control panel. I just looked at the circuit board for the control panel. It is fed 12VDC+ from the red wire. On the other side of the fuse fed from the circuit board is the 12VDC+ for the water pump, battery condition guage and the panel light.
The holding tank lights should not light up unless there is waste water in the tank.
Old 02-27-2011, 03:56 PM   #17
1973 31' Sovereign
Montalba , Texas
only thing i did not hook up is the ammeter wires everything esle is connected not sure about tv it works on 110
Old 02-27-2011, 04:18 PM   #18
1973 31' Sovereign
Montalba , Texas
thanks guys i do now have power to control panel water pump and other functions working properly no indictor light but i can live with that for now thanks again
Solar Panel Prices Dropping tbro Generators & Solar Power 11 03-30-2011 09:21 PM
monitor panel on a 70 overlander rayandre Electrical - Systems, Generators, Batteries & Solar 4 02-14-2011 07:09 AM
How to repair the control panel? DougZ General Repair Forum 1 01-10-2011 06:52 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 08:01 PM
