Old 02-27-2011, 03:48 PM   #15
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
That circuit gets it power at one end from the fuse panel, but also feeds power to the battery from your TV. Since this all started with replacing the fuse panel, I would focus in on that area first.
Richard
Old 02-27-2011, 03:55 PM   #16
x
XXXX , XXXX
The 73 service manual shows a seperate red wire powering the control panel. I just looked at the circuit board for the control panel. It is fed 12VDC+ from the red wire. On the other side of the fuse fed from the circuit board is the 12VDC+ for the water pump, battery condition guage and the panel light.
The holding tank lights should not light up unless there is waste water in the tank.
wasagachris is offline   Reply With Quote
Old 02-27-2011, 03:56 PM   #17
1973 31' Sovereign
Montalba , Texas
only thing i did not hook up is the ammeter wires everything esle is connected not sure about tv it works on 110
mkcox is offline   Reply With Quote
Old 02-27-2011, 04:18 PM   #18
1973 31' Sovereign
Montalba , Texas
thanks guys i do now have power to control panel water pump and other functions working properly no indictor light but i can live with that for now thanks again
Solar Panel Prices Dropping tbro Generators & Solar Power 11 03-30-2011 09:21 PM
monitor panel on a 70 overlander rayandre Electrical - Systems, Generators, Batteries & Solar 4 02-14-2011 07:09 AM
How to repair the control panel? DougZ General Repair Forum 1 01-10-2011 06:52 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 08:01 PM
